Old 01-07-2016, 08:42 AM   #1
tmontague
tmontague's Avatar
was the drive belt changed recently? Usually the vvt solenoid never dies unless it is physically damaged (commonly by leveraging against it when changing the drive belt).
That being said I'm not aware of a bad vvt solenoid causing a misfire. It's not likely that it is the coil packs since it's all 4. Not too sure what else it could be other than a bad/dirty maf or bad vacuum leak (that said it would've thrown a lean code if it was a vacuum leak).
Can you check fuel trims using a obd reader?
Old 01-07-2016, 08:50 AM   #2
Zachccccc
I've made a toast!
Drives: 2001 Echo
Nah the drive belt wasn't changed. I think the VVT code was secondary to the actual issue. Maybe the faulty something goofed up the VVT ? But I dunno.
I'm going to try and clean the MAF tonight and see if that doesn't fix the problem. If not the next step will be buying a new MAF
I don't personally own an obd reader, so I can't check unfortunately.
Any other checks for a vacuum leak ?
Zachccccc is offline   Reply With Quote
DIY: Intake Installation redyaris DIY / Maintenance / Service 53 08-23-2014 05:34 AM
New Engine Management System offered for the 1NZFE Dezod Forced Induction Forum 51 06-16-2011 10:33 AM
