Old 01-07-2016, 02:56 PM   #1
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Originally Posted by tmontague View Post
The pre cat O2 sensor is an AFR sensor (wideband), the post cat is a typical short band O2 sensor.
I believe Blue vits is referring to the primary AFR sensor, but you may as well check both.
The primary is NOT an AFR on an Echo. It is an O2 sensor.
And yes the post Cat O2 Sensor will influence the long term fuel trim.
The primary is before that Cat. It is connected in the engine bay. The connector is mounted to the rear engine mount and is a PITA to disconnect. The secondary O2 is the one connected under the shifter.
Old 01-07-2016, 03:00 PM   #2
Zachccccc
I've made a toast!
Drives: 2001 Echo
So to test the Primary do the voltmeter pin check and it should oscillate from .4-.9v ?
I'm still not certain which pin to test the white one on the OBD ?
How would one go about replacing that sensor if it is bad, any tips/tricks ?
Also, are there tests that can be done to diagnose a bad MAF?
Actually the misfire is probably what caused the 420 code.
It's actually crazy how far out the readings on the sensors can be screwing with other components and not set a code.
Oh, ok gotcha !
Zachccccc is offline   Reply With Quote
DIY: Intake Installation redyaris DIY / Maintenance / Service 53 08-23-2014 05:34 AM
A Mystery Oi'll Say! Yar Is Word Fuel Economy Forum 16 05-11-2013 04:22 AM
New Engine Management System offered for the 1NZFE Dezod Forced Induction Forum 51 06-16-2011 10:33 AM
