Old 01-11-2016, 01:53 AM   #1
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Hey, they installed your engine backwards!
Just kidding...
...the US engines have the intake in the front and exhaust in back. You might gain a little by ducting your intake out the front. I'd try a temporary experiment with tape and some cheap flexible clothes dryer ducting just to see what happens. Does anyone make a long tube exhaust header for your engine? If they do, that's the surest way to increase your engine's low end torque. Longer exhaust runners make more torque.
Greg
Old 01-11-2016, 05:41 AM   #2
lormagni
Drives: Toyota Yaris 1.33 SR
Just kidding...
Greg
Hahaha, I know it's backwards, the 1NR-FE is made this way! I think I'll try that way, ducting the intake to the front. Unfortunately there is no aftermarket header for my engine, the 2010 version of this engine had a longer 4-2-1 tube header (first picture), then in 2012 they changed it for a shorter 4-1 one (second picture) , I don't know why. I'm kindly disappointed with this engine, it seems that there are no aftermarket parts at all, maybe only something for the R1 rally version (http://www.topspeed.com/cars/toyota/...-ar133663.html). I think that the only way to improve performance is to invest in something custom made, or maybe just buying another car... :(
lormagni is offline   Reply With Quote
Old 01-11-2016, 12:01 PM   #3
tooter
play every day
tooter's Avatar
The older 4-2-1 header is better. It appears that the design of the newer one is to comply with more stringent emissions regulations at the expense of performance. If it's not too big of an expense, I'd try one of those just to see if might help. One way to make your car more fun to drive is to install an aftermarket muffler that makes a nice sound. Or put wheels, wider lower tires and better suspension to make it corner better. I bet you get great gas mileage with the 1.3. That's what they're made for more than performance.
I ride a scooter with a tiny 49cc engine. I installed an exhaust and now it sounds like a Formula 1 racer!
Greg
Old 01-11-2016, 12:25 PM   #4
lormagni
Greg
That's what I've done until now, my current mods are: Vogtland lowering springs + uprated shocks, Japan Racing 16x7 et40 wheels (TE37 replicas) and a sport muffler from Ulter (even if it doesn't make too much noise, because it's under European homologation that doesn't allow too much noise from mufflers). All these changes are good for car handling and sound, but I'd like to add something more to the engine, because it's nice and pushy and only suffers from those f***ing emissions regulations and is too much low-fuel consumption oriented.
I think that the worst part of this engine is the 6sp gearbox (the 1st and 2nd gears are wayyy too long) that combined with a heavy flywheel and a choked header gives poor acceleration.
By the way I was surfing on the internet and I found that this engine is very similar in some parts to the other Dual VVT-i engines such as the 2ZA-FE used on the Camry and Scion TC, look for example at the manifold or the flywheel, or even the engine configuration with the intake in the back and the exhaust header in the front . It would be good to find out if there are actually some interchangeable parts between these engines...
PS: nice Ruckus, last year I was going to pick one, it seems so much fun to drive!
Old 01-12-2016, 11:25 AM   #5
tooter
play every day
tooter's Avatar
Sounds like you've done really practical mods!
Your engine is dual VVT-I? That's better than the US engines which are only single.
Toyota is notorious for employing multiple uses of the same well designed parts. I believe this economics driven efficiency is one reason they make such reliable vehicles.
I liked the chopped off short "cue ball" shifter I had made for my 1996 Toyota pickup, and when I bought a new Toyota pickup in 2012... that 17 year old shifter bolted right on to the new transmission!
Do do some fishing around on other Toyota engines just to see what you might come up with. I adapted an intake manifold off of an old 1998 Toyota Corolla to fit my 2012 Yaris.
Simota CF650-6 Air Intake Review invader166 Performance Modifications 16 12-21-2015 03:31 PM
JB Weld stock intake manifold port w/ 1ZZ Throttle Body tmontague Performance Modifications 2 10-07-2015 09:31 PM
tooter's manifold adventure... tooter Performance Modifications 1465 07-31-2014 08:11 PM
Anyone tried to appy Apexi SAFC or anything similar on their YARIIIII?? oscarying Performance Modifications 25 10-21-2006 09:42 PM
