play every day
The older 4-2-1 header is better. It appears that the design of the newer one is to comply with more stringent emissions regulations at the expense of performance. If it's not too big of an expense, I'd try one of those just to see if might help. One way to make your car more fun to drive is to install an aftermarket muffler that makes a nice sound. Or put wheels, wider lower tires and better suspension to make it corner better. I bet you get great gas mileage with the 1.3. That's what they're made for more than performance.
I ride a scooter with a tiny 49cc engine. I installed an exhaust and now it sounds like a Formula 1 racer! ![]() ![]() Greg |
#2 | |
![]() ![]() Drives: Toyota Yaris 1.33 SR Join Date: Nov 2014
That's what I've done until now, my current mods are: Vogtland lowering springs + uprated shocks, Japan Racing 16x7 et40 wheels (TE37 replicas) and a sport muffler from Ulter (even if it doesn't make too much noise, because it's under European homologation that doesn't allow too much noise from mufflers). All these changes are good for car handling and sound, but I'd like to add something more to the engine, because it's nice and pushy and only suffers from those f***ing emissions regulations and is too much low-fuel consumption oriented. I think that the worst part of this engine is the 6sp gearbox (the 1st and 2nd gears are wayyy too long) that combined with a heavy flywheel and a choked header gives poor acceleration. By the way I was surfing on the internet and I found that this engine is very similar in some parts to the other Dual VVT-i engines such as the 2ZA-FE used on the Camry and Scion TC, look for example at the manifold or the flywheel, or even the engine configuration with the intake in the back and the exhaust header in the front . It would be good to find out if there are actually some interchangeable parts between these engines... PS: nice Ruckus, last year I was going to pick one, it seems so much fun to drive! Last edited by lormagni; 01-11-2016 at 01:07 PM. |
play every day
Sounds like you've done really practical mods!
![]() Your engine is dual VVT-I? That's better than the US engines which are only single. Toyota is notorious for employing multiple uses of the same well designed parts. I believe this economics driven efficiency is one reason they make such reliable vehicles. I liked the chopped off short "cue ball" shifter I had made for my 1996 Toyota pickup, and when I bought a new Toyota pickup in 2012... that 17 year old shifter bolted right on to the new transmission! ![]() ![]() Do do some fishing around on other Toyota engines just to see what you might come up with. I adapted an intake manifold off of an old 1998 Toyota Corolla to fit my 2012 Yaris. ![]()
| Simota CF650-6 Air Intake Review | invader166 | Performance Modifications | 16 | 12-21-2015 03:31 PM |
| JB Weld stock intake manifold port w/ 1ZZ Throttle Body | tmontague | Performance Modifications | 2 | 10-07-2015 09:31 PM |
| tooter's manifold adventure... | tooter | Performance Modifications | 1465 | 07-31-2014 08:11 PM |
| Anyone tried to appy Apexi SAFC or anything similar on their YARIIIII?? | oscarying | Performance Modifications | 25 | 10-21-2006 09:42 PM |
