Old 01-12-2016, 12:21 PM   #1
Eforno
Drives: Toyota Yaris 2014 LE
Originally Posted by Absolutely Red 12 View Post
Remove the lower steering column cover.
Locate the connector shown in my picutre.
Tap the fog switch wires, one to the violet, and the other to the green wire.
The two by themselves.
You can alternatively not use a switch, and jump the two wires, they will go on, and stay on when the headlights are turned on.
I tried PMing you but it didn't work for some reason; I see no record of it in my sent inbox. I've read this entire thread and I am still confused with how the wiring works. How exactly do you jump a wire? Scott's definition is to connect it with the switch, but how do I jump it without anything, as to test if the relay is there or what not. All I can think of when it comes to jumping a wire to to slice it open and then twisting it together.
Eforno is offline   Reply With Quote
Old 01-12-2016, 06:34 PM   #2
Tap Splice connectors are the easiest way. They bite through the insulation on two pieces of wire to make the connection:
Old 01-13-2016, 12:13 AM   #3
Eforno
I thought of scotchlocks when Absolutely Red 12 mentioned tapping the wires from the fog switch to Pin 3 and 4; I was just confused about what it meant to "jump" a wire, because I wasn't expecting to have to splice into any wires just to "check/test" them. Instead, I thought using something like an alligator clip wire to clip onto each pin would work; because if I jumped 2 wires with a tap and they happened to be the wrong ones, I'll end up having to seal the plastic insulation of each wire, as caused by the removal of the tap. (I don't even know if using alligator clips to jump wires would work. I made that whole scenario up in my head w/o any electrical/wiring knowledge)
So just to clarify, to jump wires that are inserted into a connector, I should pull one of the wires w/ the pin out, cut the pin off, and then t-tap it to the pin wire that is still in the connector?
Another thing I can't really comprehend is, how is it that purple and green wire in Absolutely Red 12's picture pin 3 & 4, respectively, if when the connector is oriented like this: .
And as for the fog light switch, can I just tap any of the two of the four switch wires to the purple or green pin wires? What do I do with the remaining two wires from the fog light switch? Fuse tap one of the wire to dash illumination, and ground the other wire?
I sorry I have so many questions, and I know many may have already been answered in other threads, but thank you so much for always answering CTScott
2012 Fog Light Kits TimmyTwo2 Third Gen Yaris General Discussion 4 10-06-2014 03:41 PM
2012 Fog lights FIY Absolutely Red 12 Third Gen Yaris General Discussion 1 09-17-2012 10:31 PM
2012 Yaris LB Fog Lights TimmyTwo2 Cosmetic Modifications (Exterior/Interior) 6 03-21-2012 04:54 PM
Need fog light switch and relay Jrilla DIY / Maintenance / Service 23 07-01-2011 11:12 AM
