Originally Posted by CTScott
Tap Splice connectors are the easiest way. They bite through the insulation on two pieces of wire to make the connection:
I thought of scotchlocks when Absolutely Red 12 mentioned tapping the wires from the fog switch to Pin 3 and 4; I was just confused about what it meant to "jump" a wire, because I wasn't expecting to have to splice into any wires just to "check/test" them. Instead, I thought using something like an alligator clip wire to clip onto each pin would work; because if I jumped 2 wires with a tap and they happened to be the wrong ones, I'll end up having to seal the plastic insulation of each wire, as caused by the removal of the tap. (
I don't even know if using alligator clips to jump wires would work. I made that whole scenario up in my head w/o any electrical/wiring knowledge)
So just to clarify, to jump wires that are inserted into a connector, I should pull one of the wires w/ the pin out, cut the pin off, and then t-tap it to the pin wire that is still in the connector?
Another thing I can't really comprehend is, how is it that purple and green wire in Absolutely Red 12's picture pin 3 & 4, respectively, if when the connector is oriented like this:
And as for the fog light switch, can I just tap any of the two of the four switch wires to the purple or green pin wires? What do I do with the remaining two wires from the fog light switch? Fuse tap one of the wire to dash illumination, and ground the other wire?
I sorry I have so many questions, and I know many may have already been answered in other threads, but thank you so much for always answering CTScott
