#1 | |
side note: do you think the new corolla 6 speed would fit on your 2zrfe in your yaris engine bay? by extension, would the corolla 6 speed bolt to a 1nzfe AND fit between the frame rails?
Data doesn't lie
Drives: That Scrappy 2zrVios Join Date: Oct 2014
When we swapped the Xd 2zt/C50 into Computerlove's 09 LB, we used a big hammer to make room....so I would assume it would be the same procedure for any non-1nz power train
Data doesn't lie
#4 | |
![]() Drives: 08 yaris 1.8 dual vvti 5sp Join Date: Feb 2010
No hammer needed when using a EC series 6sp transmission,the cases of the new EC 6sp transmissions are shorter,the length is about the same as the older 5 sp
c series transmissions.This is due to new case and gear design, Toyota went to a 2 piece case design.(c transmissions are a three piece case) In Europe ,the yaris used a EC 6 sp on later generations of the 1.8 ts and 1.33. Last edited by froger; 04-22-2016 at 09:29 AM. |
#6 | |
2ZR swap. DO IT! Ask how!
Data doesn't lie
Here are some pictures from my RPM long tube header install...
Data doesn't lie
No way around it, the coating will get scratched upon install. I had to bend the bracket tab to get this in from underneath, and I also had to make a indent on the firewall for A/F sensor clearance
Data doesn't lie
This is how my exhaust shop did my midpipe. RPM sent me an extra flange and gasket to make this a bolt-in header. I highly recommend installing a flex joint though, as I get a lot of vibration at idle with the a/c on...
Data doesn't lie
This is my rear O2 sensor extension, this is required with the RPM header due to its length.
![]() ![]() ![]() Drives: 07 HB YARIS, 15 JUKE, 00 TUNDR Join Date: Mar 2007
Very nice.
![]() Drives: 11 GSE21, 86 AE86 Join Date: Apr 2016
The ZSP90 used the same clutch master cylinder with the C56 and EC67.
If you bought an EC67 and it didn't come with any of the hydraulics, the following parts are what you'd need: 31400-59015 - Cylinder, Slave (with integrated release hub, includes bolts) 31407-52010 - Bleeder, Clutch Slave 91551-80820 - Bolt, Clutch Slave Bleeder (Qty: 2) 31482-52090 - Tube, Clutch (Slave to Bleeder) 31126-20090 - Boot, Clutch Tube 31482-52100 - Tube, Clutch Bleeder to Flexible Hose 90461-08567 - Clamp, Bleeder to Hose Tube 31484-52160 - Bracket, Tube to Hose (Transmission Side) 91671-80810 - Bolt, Tube and Bracket (Qty: 2) 90947-02G28 - Hose, Transmission to Body Everything on the body side is the same between the C56 and EC67. There are LH mount differences as well, however the RH/rear mounts are the same for C56 and EC67. The axles are the same between the two as well. 12372-37141 - Mount, RH Side 12325-37100 - Bracket, RH Mount 12351-37100 - Damper, RH Mount Jeff
![]() 2011 Lexus IS350 6MT F-Sport with LSD 1986 Toyota Corolla GT-S Supercharged with TRD Stuff 2005 Toyota Yaris RS 5MT Short Track Car |
Data doesn't lie
So this happened...
Awesome. When does it air?
I've been looking forward to that video for a while! Let us know when it's put up
Data doesn't lie
I think it takes a week to air, I'll keep you guys updated. It was so awesome, he made some bold statements about how fast the car is through the canyon!
![]() ![]() Drives: 2007 Toyota Yaris Join Date: Nov 2015
Sic
| unusual engine swap | CoryM | Performance Modifications | 26 | 10-09-2015 12:17 AM |
| ***How to Choose an Exhaust System*** | Hussain-Vtec | Performance Modifications | 16 | 03-16-2014 08:02 AM |
| engine swap | djhuddy2442 | Performance Modifications | 6 | 04-11-2013 01:05 AM |
| Boost Gets U Laid eh? Count me In | yaris2010RS | Forced Induction Forum | 128 | 02-02-2013 04:57 PM |
| Scion/Yaris engine swap | mrrock | Performance Modifications | 1 | 03-02-2011 06:56 PM |
