Old 03-09-2017, 10:20 AM   #1
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
So if the 2zr motor is pretty easy swap.. I am curious, being that the corolla uses the 2az motor as well as the 2zr, if the 2az would be somewhat similar....
I think first you'd have to check if both motors use the same mounts in the corolla.
Old 03-09-2017, 10:27 AM   #2
tmontague
tmontague's Avatar
The other issue is the engine harness for the 2az likely doesn't match up to the yaris harness like the xd's does.
Doesn't mean it wouldn't work, your just have a lot of rewiring to do and your want to have wiring diagrams for both cars to know what ever wire does on the engine harness
Old 03-09-2017, 01:12 PM   #3
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
That's actually pretty east to research, you just need a subscription to Toyota TechInfo.
Old 03-09-2017, 10:30 AM   #4
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
True true.. also size may play a factor. Probably not enough room in the yaris if it is a tight fit in a corolla
-Derrick-
Old 03-09-2017, 10:39 AM   #5
m.flores.0928
m.flores.0928's Avatar
Drives: 2014 Yaris
Also make sure if you run just a motor swap without the transmission, that the 2AZ mounts up to the Yaris trans. You may want to do a whole powertrain swap with trans and axles.
m.flores.0928 is offline   Reply With Quote
Old 03-09-2017, 11:14 AM   #6
tmontague
tmontague's Avatar
the 2zr in considerably tallker than the 1nz and seems to be wider as well. Not too sure how the 2az compares size wise to either engine
Old 03-09-2017, 12:15 PM   #7
ilikerice
ilikerice's Avatar
Yea, be we are talking about a 1.5L to a 1.8L which having a longer stroke in the crank (if the cylinders are the same size) will make the engine taller and wider obviously.. but now the 2az is a 2.4L, so I am sure that boy is much fatter
-Derrick-
Old 03-11-2017, 12:20 PM   #8
tarkus
tarkus's Avatar
Drives: 2006 Yaris RS 3-Door
My wife's Camry has that engine, and it's a pretty huge block. I can't think of any way you could make it fit into a Yaris, at least not without a lot of cutting and welding in the engine bay. Plus, I think it would make a Yaris very nose heavy.
Sent from my phone with Tapatalk. Please excuse any typpos.
tarkus is offline   Reply With Quote
Old 03-09-2017, 11:44 PM   #9
ArmstrongRacing
Data doesn't lie
ArmstrongRacing's Avatar
Drives: That Scrappy 2zrVios
I actually located and prepared to do the 2az swap 4 months ago. A guy wanted a 2zr swap, so I offered him mine and I would attempt the 2az.
The project got abandoned once the buyer backed out, oh well. I'm sure every 2az ECM has immobilizer anyway
Old 03-10-2017, 08:47 AM   #10
CrankyOldMan
The 2AZ also mates to an E351 gearbox, so it's probably not a direct fit to the C50.
Old 03-10-2017, 09:29 PM   #11
ArmstrongRacing
Data doesn't lie
Needing a transmission and axles also makes the 2.4L swap much more difficult and expensive. It would be cool but not easily performed like the 2zr. It may be cheaper to buy a turbo kit for the 2zr vs attempt the 2az swap
Old 03-10-2017, 11:28 PM   #12
CrankyOldMan
I'll just leave this here...
http://www.turbokits.com/Toyota/Corolla/Turbo_Kits/
Old 03-11-2017, 10:01 PM   #13
ArmstrongRacing
Data doesn't lie
Originally Posted by CrankyOldMan View Post
ON SALE FOR $2990!!!!!
Old 03-11-2017, 10:09 PM   #14
m.flores.0928
Drives: 2014 Yaris
Is that a lot? I've never researched mods like this before
Old 03-11-2017, 09:10 AM   #15
ilikerice
ilikerice's Avatar
Turbo kit... would Probably have to be custom header and down pipe... but would use the piping and other components from a yarisingle zage kit..
-Derrick-
Old 03-11-2017, 10:50 PM   #16
tarkus
tarkus's Avatar
That's a steal!
Old 03-12-2017, 12:09 AM   #17
ArmstrongRacing
Data doesn't lie
Ok guys, here's the video from last weekend.
https://youtu.be/PysI8WmcaT0
Old 03-12-2017, 07:23 AM   #18
Fosco
Drives: Yaris 2006 2ZZGE
5 bucks less
http://monkeywrenchracing.com/produc...-matrix-09-13/
But you will probably would like to upgrade the turbocharger to gt2860rs
Fosco is offline   Reply With Quote
unusual engine swap CoryM Performance Modifications 26 10-09-2015 12:17 AM
engine swap djhuddy2442 Performance Modifications 6 04-11-2013 01:05 AM
Boost Gets U Laid eh? Count me In yaris2010RS Forced Induction Forum 128 02-02-2013 04:57 PM
Scion/Yaris engine swap mrrock Performance Modifications 1 03-02-2011 06:56 PM
