Data doesn't lie
Drives: That Scrappy 2zrVios Join Date: Oct 2014
There is no way to use a sandwich plate adaptor on the 2zr, it has a canister filter. The gauge sensor goes where the dummy light switch is.
www.Facebook.com/ArmstrongRacingPage www.youtube.com/c/ArmstrongRacing www.instagram.com/Armstrong_Racing http://www.wheelwell.com/profile/55f...35ac4a/garage/ Last edited by ArmstrongRacing; 01-30-2016 at 01:14 PM. |
Data doesn't lie
I would like everyone to read through this guide and inform me of any unclear elements. Also, Is this thread going to be a sticky or will it disappear once everyone gets over the excitement
![]() ![]() Drives: 07 Yaris Join Date: Sep 2012
I've been following this thread since start, and I know it's a long shot...
But I think it would be helpful to see something like this (below), so that people can get sense of what their options are. I recall you saying the Xd swap was easy, only four wires, and I think a lot of people thought the corolla swap was going to be the same idea. That's probably why the confusion in the earlier pages when they saw you doing the wiring. Would be nice to outline what was used for the swap, as far as what ECU is needed, what axles are compatible, transmission options, what mounts to use, technical difficulty of wire splicing involved, etc. I know you haven't done the Matrix swap, yet , but that could stay blank for now...You should also do up a DIY on that oil pressure gauge! |
#4 | |||
2ZR swap. DO IT! Ask how!
![]() ![]() Drives: 2007 Toyota Yaris Join Date: Nov 2015
#6 | |
Anyone have any ideas how you'd go about getting around the engine immobilizer issue? My thoughts are you'd need to purchase the ecu that came with the new engine and remove the stock Yaris ECU. Then you'd probably also need to immobilizer module located on the steering wheel from the donor car and then have to swap that into the yaris. Problem is, are all of these other parts plug and play when swapped from a donor car to Yaris?
Data doesn't lie
Yeah.....Im not creating a chart. If you or someone else wants to create a chart ill be happy to share the info with you. I did however add a list of components to post #1.
Update: 232 problem free miles accumulated so far, no CEL, and EVERYTHING works fine. My first autocross is tomorrow, look for the video on my YouTube channel or FB page.
www.Facebook.com/ArmstrongRacingPage www.youtube.com/c/ArmstrongRacing www.instagram.com/Armstrong_Racing http://www.wheelwell.com/profile/55f...35ac4a/garage/ Last edited by ArmstrongRacing; 01-31-2016 at 11:49 AM. |
Data doesn't lie
Good info Cranky, good work.
On a side note, the 2zrVios took a foul weather win today in SMF. 2 Civics and a Mini fell victim to the 2zr. You can see a short video clip on my FB page: https://m.facebook.com/story.php?sto...1&ref=bookmark |
#10 | |
I love the comment from the announcer: "...an automatic Yaris! Oh no!" |
Data doesn't lie
Haha, the amount of trash talk I hear about the auto from people that dont know me is funny...people don't understand circuit racing is 70% driver skill....within classes a small percentage of what makes you a winner is car setup.
FWIW after reading some sites of other car's I came to this conclusion:
If you just swap in a 2zr engine and loom and keep the original ECU,immobilizer and keys then there will be no issue. The immobilizer will read the correct key and alow the car to start and run with no issues. Someone please correct me if I'm wrong
Data doesn't lie
A ECM designed to run the 1nz will NOT run a 2zr.....completely different due to the dual vvti....but hey, everything on the internet must be true right? Lol.
#14 |
yes, very true. I should've clarified my above post. The ECU would not be needed for the immobilizer to work so you could install a matrix ecu for the 2nz and be fine. This was working for some Infinite owners.
Does the immobilizer use the ECU or is it simply just reading the key?
#15 |
The 08-09 xD did not have an immobilizer. The 09+ Yaris does. From what I can tell, the immobilizer has dedicated signal lines to the ECU. If the signals aren't there, the car won't turn over. My thought is that if the ECU doesn't have the inputs from the immobilizer in the first place, it doesn't matter that the key transponder and immobilizer are still in the vehicle. As far as I can see, there's no other connection from the immobilizer to the starter switch or relays.
Take it with a grain of salt, I haven't actually done the swap. Edit: Here's the wiring diagram for the Yaris immobilizer. The only communications line that doesn't go directly to the ECU is pin 9, which is wired to the OBD II/DataLinkConnector (pin 7 - SIL). As far as I know, that's only used for external diagnostics. I would add a picture of the xD, but there's nothing to show for unused connections on the diagrams. Last edited by CrankyOldMan; 02-02-2016 at 07:09 PM. |
#16 | |
SIL is the K line of ISO-9141. It was used for OBDII diags prior to CAN, but was used for the immobilizer and the comm between the SRS ECU and the ECM on 2nd gen Yaris and various other Toyotas up to 2012.
#17 | |
#18 | |
Unfortunately the opposite is not true, where installing an immobilized ECM in a non-immobilizer car eliminates the immobilizer function.
| unusual engine swap | CoryM | Performance Modifications | 26 | 10-09-2015 12:17 AM |
| ***How to Choose an Exhaust System*** | Hussain-Vtec | Performance Modifications | 16 | 03-16-2014 08:02 AM |
| engine swap | djhuddy2442 | Performance Modifications | 6 | 04-11-2013 01:05 AM |
| Boost Gets U Laid eh? Count me In | yaris2010RS | Forced Induction Forum | 128 | 02-02-2013 04:57 PM |
| Scion/Yaris engine swap | mrrock | Performance Modifications | 1 | 03-02-2011 06:56 PM |
