Data doesn't lie
Drives: That Scrappy 2zrVios Join Date: Oct 2014
The 2zr-fe engine swap guide
...And so it begins. The 1.8L dual vvt-i 2zr-fe is a relatively new engine, released in 2007. This engine produces 136hp/129ftlbs at the crank in stock form, and is a smog legal swap when done properly. There is great aftermarket support with people making 150hp n/a with flow mods, or 200hp+ with available superchargers and turbo kits. I chose to get my swap components from a auto recycler instead of buying a scion xd. My engine is from a 2013 Corolla with 34k on the odometer(the valve cover writing is wrong)...a great find. My car is automatic and Ive kept the auto for now to check compatibility. Lets start, here's whats needed:
1)2ZRFE engine with ALL components and accessories from a 2009+ Xd, Corolla 2)ECM from a 2008-2009 Xd applicable to your car in auto or manual trans 3)Xd engine harness also applicable to your car and transmission choice. 4)Xd RH and LH engine/transmission mount and brackets 5)Xd exhaust midpipe 6)Xd intake AND MAF sensor 7)Xd or Corolla flex plate(auto), flywheel/clutch(manual) 8)Mini-add-a-circuit and soldering equipment *With the help of other YW members, I have started a collection of 2ZRFE parts to make everyones swap a little easier, just contact me for details!* Read through the entire thread to learn as much as possible before beginning. Good luck!
www.Facebook.com/ArmstrongRacingPage www.youtube.com/c/ArmstrongRacing www.instagram.com/Armstrong_Racing http://www.wheelwell.com/profile/55f...35ac4a/garage/ Last edited by ArmstrongRacing; 11-14-2016 at 01:39 AM. |
Data doesn't lie
If you go through a recycler you need to prepare yourself to make a ton of phone calls and be clear about what you need and how you want it. Expect to spend roughly $3000 total for everything needed. You can also buy a entire wrecked car if you like, but it will cost you more. You want everything that was originally attached to the engine, including ecm, exhaust, airbox(xd), passenger engine mount(xd), ect. Ill cover all of this throughout my install.
Data doesn't lie
The first thing I checked was compatibility with the yaris c50 transmission. The 2zr and 1nz flywheels/Flexplates are the same size, the only difference is the 2zr has 8 bolts where the 1nz has 6.....so use the 2zr flywheel and your 1nz clutch.
Data doesn't lie
The bell housing flanges on the 2zr and 1nz are also the same, both are a 9bolt 2-o'clock starter orientation. Apply a little grease to the dowels, and you can use the 1nz starter.
Aaaamazing
much winning
![]() ![]() ![]() Drives: MR2 Spyd/Type R/Yaris/Civic Si Join Date: Feb 2007
Armstrong Racing for President !
![]() ![]() Drives: Yaris '05 1.3 Hatch "R.I.P." Join Date: Aug 2014
So stoked that it is finally happening! Gonna dump my 1JZ Cressi swap plans and rather invest my time and money in this! Whack damn son!
![]() ![]() Drives: Yaris 07 HB Join Date: Apr 2011
Yuppiii!!
![]() ![]() ![]() Drives: 2013 Yaris Hatchback L Join Date: May 2013
Awesome! Great information.
Data doesn't lie
I ordered the xd airbox, engine mount, and maintenance items today. They should be in tomorrow, now I just gotta get an ecm and start the wiring.
#13 | |
2ZR swap. DO IT! Ask how!
On a format note: I'm not sure if the file size is the reason for only one picture per post, but it would be much more helpful to have the whole process in the first few posts instead of having to sort through lots of replies to find the content. |
Data doesn't lie
My plan was to document each step carefully with one picture for each step. Yes there will be replies to read through, but some of those comments could be good information in case there are questions.
#15 | |
Can't you just edit the last post and keep adding to it. Upload the pictures to photobucket.com and link the pictures. You can add as many as you want to that way. Sent from my iPod Touch |
Data doesn't lie
I went through the wiring diagrams today and verified the 2zr ECM(automatic transmission) and harness are mostly plug-n-play with the Yaris U340E. For you guys using a manual transmission, you need a manual trans specific harness and ECM.
www.Facebook.com/ArmstrongRacingPage www.youtube.com/c/ArmstrongRacing www.instagram.com/Armstrong_Racing http://www.wheelwell.com/profile/55f...35ac4a/garage/ Last edited by ArmstrongRacing; 01-25-2016 at 11:18 PM. |
#17 | |
![]() ![]() Drives: 07 Yaris 3 door Join Date: Feb 2013
One of my other concerns is emissions. When you swap to a different car ECM, I'm wondering what kinda of problems that will create when one goes for their annual emissions testing? Doesn't the computer store the VIN info, and I wonder if it will throw a red flag when the emissions testing machine is hooked up to your car, and the VIN #s don't jive? |
Hmm, that is my only concern w/ emissions. I know here in Ontario they care solely on the obd scan and making sure that they're are no codes but i'm not sure if they check to see if the ecu matches the Vin on the car
| unusual engine swap | CoryM | Performance Modifications | 26 | 10-09-2015 12:17 AM |
| ***How to Choose an Exhaust System*** | Hussain-Vtec | Performance Modifications | 16 | 03-16-2014 08:02 AM |
| engine swap | djhuddy2442 | Performance Modifications | 6 | 04-11-2013 01:05 AM |
| Boost Gets U Laid eh? Count me In | yaris2010RS | Forced Induction Forum | 128 | 02-02-2013 04:57 PM |
| Scion/Yaris engine swap | mrrock | Performance Modifications | 1 | 03-02-2011 06:56 PM |
