Old 01-21-2016, 10:32 AM   #1
ArmstrongRacing
Data doesn't lie
ArmstrongRacing's Avatar
Drives: That Scrappy 2zrVios
You are mixing scenario's up in 2 different posts and I can see how this can get confusing and intimidating for someone who is a newbie with wiring.
Im sorry for the confusion, but I mention the Corolla harness because thats what I'm using on my 2zr/yaris trans buid. I wanted to test ALL of the Corolla parts so no one else would have to. I want this to be easy for everyone, so again just to be clear........aside from the actual engine and accesories, USE EVERY PART FROM A SCION XD.
I know you guys would prefer this diy be formatted a certain way, but I am sharing this info with you guys as I go.
Old 01-24-2016, 12:00 PM   #2
CoryM
Drives: 2009 5-door, 5-speed
You're doing great. Keep it up! Whenever I do something worth sharing, I always find it difficult to document until after it's done. The effort is appreciated.
Cheers.
Old 01-24-2016, 12:37 PM   #3
3cyltrbo
Cheers.
+1
3cyltrbo is offline   Reply With Quote
Old 01-24-2016, 12:46 PM   #4
ArmstrongRacing
Data doesn't lie
This is exactly how I felt about this diy, there is so much going on I feared a step would get forgotten if I waited until it was completed.
Old 01-24-2016, 02:11 PM   #5
beaker
Drives: 07 Yaris 3 door
You're doing great! Worthy of many accolades for doing and sharing with the rest of us this engine swap.
Would you mind posting the part # of the ECM you bought, and what it was for?(ie year make model and specific options)
beaker is offline   Reply With Quote
Old 01-24-2016, 02:29 PM   #6
ArmstrongRacing
Data doesn't lie
I mentioned the ECM part# in post #23....for an automatic transmission it is: 89661-52F71.
How did the wiring go for the corrolla harness to XD/yaris?
The Corolla harness has all of the necessary wires to connect successfully to the Yaris. The cons however are that it's a monumental task soldering all of the wires, and the ecm plug is not long enough to reach the original ECM location....I had to mount mine above the valve cover on the cowl. There are also a couple wires to change for the transmission plug.
unusual engine swap CoryM Performance Modifications 26 10-09-2015 12:17 AM
engine swap djhuddy2442 Performance Modifications 6 04-11-2013 01:05 AM
Boost Gets U Laid eh? Count me In yaris2010RS Forced Induction Forum 128 02-02-2013 04:57 PM
Scion/Yaris engine swap mrrock Performance Modifications 1 03-02-2011 06:56 PM
