Data doesn't lie
Drives: That Scrappy 2zrVios Join Date: Oct 2014
I finished all of my Corolla harness soldering today. I connected the battery and switched on the ignition and I immediately got a code for P2770-Torque Converter Clutch(auto trans).....Im not sure if this is a result of the hydrolock or what, looks like I need to do a bit more research...
Tomorrow I will finish my MAF wiring and fire it up...hopefully all goes well.
www.Facebook.com/ArmstrongRacingPage www.youtube.com/c/ArmstrongRacing www.instagram.com/Armstrong_Racing http://www.wheelwell.com/profile/55f...35ac4a/garage/ Last edited by ArmstrongRacing; 01-22-2016 at 09:27 AM. |
#2 | |
![]() ![]() Drives: 07 Yaris 3 door Join Date: Feb 2013
#3 | |
Data doesn't lie
Update: (auto trans only) I've found the harness discrepancy causing my P2770 code. The Xd ECM normally receives a signal from the SL solenoid on pin#58, but my Corolla harness has that wire on 57. Also the Corolla/Xd valve body's ground this solenoid internally vs the Yaris auto trans grounding this solenoid at the ECM. I just need to swap pins 57 to 58 and ground pin #9 at the valve body connector.
www.Facebook.com/ArmstrongRacingPage www.youtube.com/c/ArmstrongRacing www.instagram.com/Armstrong_Racing http://www.wheelwell.com/profile/55f...35ac4a/garage/ Last edited by ArmstrongRacing; 01-24-2016 at 12:55 PM. |
#4 | |
| unusual engine swap | CoryM | Performance Modifications | 26 | 10-09-2015 12:17 AM |
| ***How to Choose an Exhaust System*** | Hussain-Vtec | Performance Modifications | 16 | 03-16-2014 08:02 AM |
| engine swap | djhuddy2442 | Performance Modifications | 6 | 04-11-2013 01:05 AM |
| Boost Gets U Laid eh? Count me In | yaris2010RS | Forced Induction Forum | 128 | 02-02-2013 04:57 PM |
| Scion/Yaris engine swap | mrrock | Performance Modifications | 1 | 03-02-2011 06:56 PM |
