Old 01-24-2016, 02:20 PM   #1
Keep in mind that the /65 in the tire size is the sidewall height as a ratio to the tire width. Increase the width of the tire and you need to downsize the sidewall ratio. A 195/65R15 will therefor be a taller tire than the 175/65R15 and would throw off the accuracy both your speedometer and odometer.
Old 02-19-2016, 01:54 PM   #2
jcboy
Drives: Sedan 07
not to mention that 175/65 r15 is already more than 3% bigger in diameter than the 175/65 r14 our cars were intended to have (either that or the r14s are 3% smaller )
in any case, they are right, the right upgrade for wider tires would then 195/55 r15. but 195/60 r15 is not bad, but is a larger tire, and ideally good for your highway mileage, but bad for your stop-and-go city mileage due to rotational inertia. (your car will be higher, but the fender gap will also be less.)
Existing stock tires on a wider rim, any Fuel Efficiency cons? hondaconvert Fuel Economy Forum 3 09-06-2012 12:47 AM
tire noob question..what's the widest tire size can run on stock 15"s? detroiter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 22 12-06-2011 09:44 AM
Newly installed 15" tires feel 'weird' kristan Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 04-24-2010 06:58 PM
