Does a piggyback ecu also tune for closed loop? My understanding is that the piggyback will only tune for open loop (wot acceleration). So how would one "tune" for aftermarket cams?
Does the stock ecu not re learn and over ride the piggyback under closed loop conditions?
#2 | |
![]() ![]() ![]() Drives: 2012 Toyota Yaris Sedan (Vios) Join Date: Dec 2015
advance timing flex fuel or race fuel tuning which what i did..you can use larger injectors and over spray them and tune them..stage 1: external parts..full exhaust, intake, pulleys, spark plugs etc.. you can get internal parts and tune them...stage 2: cams, pistons, rods...you can get the most expensive ecu and program the whole thing and go turbo... just dont buy one of those acceleration boot leg ecu where you plug into OBD2 and thinking your going fast... Sent from my ASUS_Z00AD using Tapatalk
Brain: ATD E85 Timing Advance ECU Engine: 1JZ Injectors, Header, Center Pipe, K&N Drop In, E85 Injector Converter Suspension: Hankook Tires, Performance OEM replacement Shocks & Springs F: 1.5 B: 1.4, Mu Spec brake pads, Front tower & Rear sway bars, Rays nut & lock Electric: Volt Stablizer & Multi gauge obd2 Cosmetic: Toyota red emblem
| 1NR-FE Performance & Tuning | nickstamat | Performance Modifications | 20 | 08-31-2010 05:02 AM |
| fog light options | charleschia1986 | Cosmetic Modifications (Exterior/Interior) | 3 | 11-13-2009 04:00 PM |
| Anyone need ECU tuning done on American Vehicles? | Nexus1155 | New England | 5 | 06-10-2009 07:15 PM |
| TRD Options | S1L3N7 D3A7H | New YARIS Purchase Forum | 26 | 01-20-2009 01:52 PM |
| FS: Redline tuning Hood Lift | yrsdrgn | Items for Sale by private party | 9 | 11-03-2008 08:15 AM |
