Old 02-02-2016, 06:57 PM   #11
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
The 08-09 xD did not have an immobilizer. The 09+ Yaris does. From what I can tell, the immobilizer has dedicated signal lines to the ECU. If the signals aren't there, the car won't turn over. My thought is that if the ECU doesn't have the inputs from the immobilizer in the first place, it doesn't matter that the key transponder and immobilizer are still in the vehicle. As far as I can see, there's no other connection from the immobilizer to the starter switch or relays.
Take it with a grain of salt, I haven't actually done the swap.
Edit: Here's the wiring diagram for the Yaris immobilizer. The only communications line that doesn't go directly to the ECU is pin 9, which is wired to the OBD II/DataLinkConnector (pin 7 - SIL). As far as I know, that's only used for external diagnostics. I would add a picture of the xD, but there's nothing to show for unused connections on the diagrams.
unusual engine swap CoryM Performance Modifications 26 10-09-2015 12:17 AM
***How to Choose an Exhaust System*** Hussain-Vtec Performance Modifications 16 03-16-2014 08:02 AM
engine swap djhuddy2442 Performance Modifications 6 04-11-2013 01:05 AM
Boost Gets U Laid eh? Count me In yaris2010RS Forced Induction Forum 128 02-02-2013 04:57 PM
Scion/Yaris engine swap mrrock Performance Modifications 1 03-02-2011 06:56 PM
