Old 02-02-2016, 07:46 PM   #1
Originally Posted by CrankyOldMan View Post
The 08-09 xD did not have an immobilizer. The 09+ Yaris does. From what I can tell, the immobilizer has dedicated signal lines to the ECU. If the signals aren't there, the car won't turn over. My thought is that if the ECU doesn't have the inputs from the immobilizer in the first place, it doesn't matter that the key transponder and immobilizer are still in the vehicle. As far as I can see, there's no other connection from the immobilizer to the starter switch or relays.
Take it with a grain of salt, I haven't actually done the swap.
Edit: Here's the wiring diagram for the Yaris immobilizer. The only communications line that doesn't go directly to the ECU is pin 9, which is wired to the OBD II/DataLinkConnector (pin 7 - SIL). As far as I know, that's only used for external diagnostics. I would add a picture of the xD, but there's nothing to show for unused connections on the diagrams.
The immobilizer is fully linked to the ECM. The Transponder key ECU reads the key and sends the key data to the ECM. Without that data the ECM will not allow the engine to run.
SIL is the K line of ISO-9141. It was used for OBDII diags prior to CAN, but was used for the immobilizer and the comm between the SRS ECU and the ECM on 2nd gen Yaris and various other Toyotas up to 2012.
Old 02-02-2016, 08:13 PM   #2
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
So even with a non-immobilizer ECM, there's still a chance that the immobilizer will prevent the engine from running (via K-line)? Is the fix for that to just get a non-immobilizer ECM and disconnect the K-line from the transponder key ECU (or remove the transponder system entirely)?
Old 02-02-2016, 08:39 PM   #3
With one of the prior 2ZR swaps I helped with there was an issue where the non-immobilizer ECM started acting like it was immobilizer enabled when the chassis still had the transponder key ECM present. So, when installing a non-immobilizer ECM you do need to make sure that the transponder key ECU is disconnected.
Unfortunately the opposite is not true, where installing an immobilized ECM in a non-immobilizer car eliminates the immobilizer function.
Old 02-02-2016, 09:06 PM   #4
CrankyOldMan
That makes sense from a design standpoint: our shift-by-wire products have to have a secondary communication system in case the direct line to the TCM fails. It's not always a second CAN line, so the K-line would be a viable backup.
Old 02-05-2016, 06:47 AM   #5
beaker
Drives: 07 Yaris 3 door
Does anyone know if the Yaris 1nz alternator and ac compressor will work on the 2zrfe? I know Armstrong Racing mentioned earlier that the starter from the Yaris would work, I'm just wondering if the Alternator and AC Compressor would also.
beaker is offline   Reply With Quote
unusual engine swap CoryM Performance Modifications 26 10-09-2015 12:17 AM
engine swap djhuddy2442 Performance Modifications 6 04-11-2013 01:05 AM
Boost Gets U Laid eh? Count me In yaris2010RS Forced Induction Forum 128 02-02-2013 04:57 PM
Scion/Yaris engine swap mrrock Performance Modifications 1 03-02-2011 06:56 PM
