Old 02-09-2016, 04:08 AM   #1
rabbito
rabbito's Avatar
every fluid and filter inside the engine..oil, air filter (K&N), cabin filter, transmission fluid(i did it anyways..), brake fluid while changing brake pads (it wasnt worn out but did it anyways), flush radiator (end of 2nd year owning the car), tires (it wasnt worn but did it anyways)..
this is what i did on begining of 40k
Sent from my ASUS_Z00AD using Tapatalk
Cosmetic: Toyota red emblem
Old 02-09-2016, 08:17 AM   #2
Tinkerman
Drives: Yaris 5 speed
Good points changing brake fluid and flush coolant.
Thank you.
Tinkerman is offline   Reply With Quote
Bought a Yaris happywanderer New YARIS Purchase Forum 5 05-15-2011 05:23 PM
Just bought 2010 yaris with 42 miles Drama New YARIS Purchase Forum 6 12-21-2010 08:35 AM
Bought a loaded Yaris!!!! Yariswhite09 General Yaris / Vitz Discussion 7 08-30-2009 09:36 AM
Just bought our 2nd Yaris Auto sedan in 20 months MauiDan New YARIS Purchase Forum 11 04-08-2009 02:53 PM
Bought lots from Sparks Toyota... drdavidr4u Cosmetic Modifications (Exterior/Interior) 4 11-21-2006 12:10 PM
