![]() Drives: yaris sedan 2011 Join Date: Oct 2016
Dear @Gagi i have yaris 2015, whithout ccs swich and im not found (60)A58= ccs pin to add ccs. pls share me diagram if you can..
regards |
![]() ![]() Drives: Yaris 1.33 vvti 2015 Join Date: Nov 2014
Is your car 1.33L gasoline european model?
Dear!this one 1.5l gas, thailan/vietnam model
![]() ![]() Drives: Yaris MK3 1.33L Dual VVT-i CVT Join Date: Jun 2014
Thank you @Gagi Thank you so much for helping me to fix ASL.
Thank you @CTScott for the wonderful tutorial How to connect cruise control What I did 1. Bought cruise control stalk and ASL switch from ebay ![]() ![]() 2. Connected cruise control stalk and plug the cable ![]() In my case Cruise control is just plug and play 3. Installed ASL switch and added a green cable from ASL and connected the other end to 2nd pin of z2 connector ![]() ![]() * Tried ASL but unfortunately it was not working. 4. With help of Gagi found a solution to short the yellow cable that is connected to z2 connector pin 1 to black cable that is coming from cruise control stalk. So first removed the Yellow cable from z2 connector ![]() Then short that with black cable from cruise control that is going to z7 connector ![]() ![]() 5. ASL is working * Before removing yellow cable for short with black cable make sure it is not connected with any cable on the connector that is located on the back side of steering wheel. ![]() Cheers ![]() ![]() ![]() Sent from my SM-G935F using Tapatalk |
Like
![]() ![]() Drives: yaris 2005 Join Date: Mar 2016
All,
I have 1NRFE Engine MT NSP120 chasis, I have installed the Cruise control light didnt comeup Any help highly appreciated. I am not sure what is not working I have clutch switch installed and assumed wiring is also installed. https://ibb.co/dQkH984 https://ibb.co/h2JwSXf https://ibb.co/9njjTcw https://ibb.co/XVw0qYw |
| DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag | CTScott | DIY / Maintenance / Service | 307 | 04-04-2023 03:43 AM |
| Cruise Control - Again! | CB900F2 | DIY / Maintenance / Service | 47 | 06-17-2010 06:29 PM |
| Retro fit Cruise Control into a 2009 Yaris hatchback | 42ezra | Performance Modifications | 1 | 05-02-2009 11:04 PM |
