![]() ![]() ![]() Drives: 2007 Join Date: Feb 2014
Check the horn fuse under the hood, that will throw the battery symbol.
#2 | |
On the 4 pin alternator connector: White: Feedback via the ALT-S fuse (check that fuse) Green: Ignition switched power (via the 10A Gauge fuse - check that too) Blue: Charging indicator output (should be +12 volts with alt running) Pink: Output to AC and ECM to let them know alt is working Also, check the two large fusible links built into the positive battery terminal. It is easy to short the wire from the battery to the alternator when changing the alternator and doing so will pop one of these.
![]() Drives: 2013 Toyota Yaris Join Date: Feb 2016
Alternator light
I checked the fuses and they look good. The wiring harness itself looks bad from the car. Looking somewhere to buy a replacement
| DIY (08' USDM Liftback): ESUSE Fog Light Install v2.0 | goku87 | DIY / Maintenance / Service | 127 | 02-19-2023 07:01 PM |
| ECU Extension Harness??? | KTS | Performance Modifications | 13 | 06-26-2014 10:03 AM |
| For Sale: AEM F/IC (FIC) 30-1910 with Boomslang Harness $400 | CTScott | Items for Sale by private party | 5 | 12-03-2013 06:07 AM |
| FS: Zage Turbo kit, AEM FIC with Pnp Harness | djgab101 | Items for Sale by private party | 32 | 04-11-2013 10:42 AM |
| How exactly does an heavier duty harness work? | IsLNdbOi | Performance Modifications | 5 | 09-26-2006 04:19 AM |
