Old 02-13-2016, 11:41 PM   #1
Frank the Tank
Drives: 2007 Toyota Yaris
Originally Posted by tmontague View Post
This my recommendation w/ 1500 USD:
rear sway bar ~ $160
Micro Image lowering springs (can find these or other for $99)
Find a used intake manifold for around $100-150 or even ebay ones (avoid $300 brand new ones)
1ZZ throttle body used ~$50
Header ~$400
Intake Manifold ~$600 used (there was one on the classifieds here)
Custom header back exhaust w/ secondary cat delete 2-2.25" diameter ~$250
If my math is right the custom exhaust will put you over your limit. I would wait on rims. The stock 15's aren't that heavy and they'll eat up your cash.
Another big handling helper is getting aftermarket rims with an offset of around +30 to 35. This makes a big difference on a small car. I noticed a lrger handling difference when I added 10mm rear spacer with -1.2 degree camber washers.
So in terms of suspension, lowering springs on oem struts/shocks and a sway bar is all that's needed?
Frank the Tank is offline   Reply With Quote
Old 02-14-2016, 12:55 AM   #2
sv650steve
Drives: accord (for now)
i was thinking the 1zz would be my best bet. How much could just afew welds really cost? I was thinking just 100 bucks. I'd do all the cuts. It sounds alot cheaper than $600.
sv650steve is offline   Reply With Quote
Old 02-14-2016, 07:56 AM   #3
tmontague
tmontague's Avatar
When cash flow is an issue yes. Ideally tokiko reds or blues are best
Comparison Test: 2012 Toyota Yaris Vs. 2012 Toyota Prius c Yar Is Word Third Gen Yaris General Discussion 27 09-06-2012 11:37 PM
Thinking Of Purchasing A Yaris TomasWillamson Cosmetic Modifications (Exterior/Interior) 2 08-16-2010 10:11 PM
Thinking about buying a 2006 Yaris Liftback kes New YARIS Purchase Forum 4 07-15-2010 07:34 PM
Thinking about getting a '06 yaris with 215 000km on it morglum New YARIS Purchase Forum 5 04-24-2009 02:47 AM
