Old 02-26-2016, 12:18 AM   #1
mehullica
Drives: Yaris 3-door
Without an oscilloscope you'll never see if the actuator or oil control valve is failing. Take out the solenoid & clean it while applying power & ground. See if that helps.
mehullica is offline   Reply With Quote
Old 02-26-2016, 05:37 AM   #2
There is also a filter for the OCV located directly below it on the block. It is a wire mesh filter, which can be removed and cleaned.
Code P0011 Error on 2007 Yaris - need help! linkkoh DIY / Maintenance / Service 10 08-13-2018 10:42 PM
