The issue w/ the oem ones is I have no idea how to adjust them to their max negative camber. I'd rather just use proper camber bolts so I know how they're adjusted
2ZR swap. DO IT! Ask how!
The OEMs have smaller diameters for larger adjustment combinations. You just push/pull the hub as far as it will go and tighten down the bolts. Unless you have an alignment rig, you don't really know how far it is, or if it's the same on both sides.
| WTB: Adjustable camber bolts and rear camber shims | Supra_Yaris | Willing to Buy by private party | 6 | 03-21-2015 06:16 PM |
| adjustable camber bolts? | b20vteg | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 12 | 08-22-2012 10:08 AM |
| Adjustable Camber Bolts | Kendrik | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 20 | 07-16-2012 04:05 PM |
| Adjustable Camber Bolts | Kendrik | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 0 | 10-31-2011 02:29 AM |
| Are camber bolts needed after installing springs? | CtrlAltDefeat | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 15 | 02-01-2009 12:19 AM |
