Old 03-05-2016, 04:39 PM   #1
klej89
Drives: Yaris
I checked this two connectors (16 and 24 pin) - all look fine. Indicator and pointers stop flashing when I pulled out and put on again after a few minutes the 7,5 Amp fuse ECU-B (some sort of reset?). Unfortunately, after a few days the problem returns... After starting the engine, everything looks good, indicator and rest do not flashing.
klej89 is offline   Reply With Quote
Old 03-05-2016, 09:59 PM   #2
The ECU-B fuse feeds constant power to various ECUs, including the cluster's microcontroller, so that makes sense that pulling it would temporarily clear the issue.
p2138 engine code crazylegs DIY / Maintenance / Service 25 08-20-2020 05:40 AM
1kr-fe engine wiring boothybunch DIY / Maintenance / Service 0 03-28-2011 03:59 AM
Engine noise and Oil Lamp on bieniman DIY / Maintenance / Service 21 12-12-2010 11:47 PM
Info regarding Engine change. sheraz2000 General Yaris / Vitz Discussion 5 01-08-2009 12:51 AM
