Old 03-09-2016, 10:53 PM   #1
CoryM
Drives: 2009 5-door, 5-speed
...if you can take some high resolution pictures of the inside of the ECM I can point you to which parts it might be and then if you have a multimeter we can figure out which one specifically it is by working our way back from the connector pin for that injector.
I was going to offer that as well, but CTScott is far more knowledgeable in this area than I. I'm curious what failed though; I've not seen a driver circuit short to ground before.
Cheers.
Old 03-09-2016, 11:16 PM   #2
Cheers.
FETs failing closed is actually fairly common. They can fail either way.
Old 03-09-2016, 11:25 PM   #3
CoryM
Good to know. I guess when I'm looking at them, it's usually because someone has done something stupid and melted it
Cheers.
Passenger Door Stuck - Repair Options? cry0 DIY / Maintenance / Service 3 07-27-2015 12:08 PM
