Old 03-11-2016, 12:10 PM   #1
lopat08865
Drives: 2008 Yaris HB
It is very unlikely the motor, as the wiper motor could not cause the washer to spray. If you want to definitely prove that, disconnect the grey wire in the smaller wiper stalk connector, which will prevent the backfeed from the washer motor to the wiper logic. When you do that the wiper will still work, and if the wiper does not pop on by itself you will verify that the problem is between the washer motor and the stalk.
Disconnected gray wire & will see if wipers ever come on by themselves. If yes then it's likely wiper motor, if no then likely a fault in the washer motor ground wire?
Disconnect of gray wire killed all washer function. Was hoping to find I could still use stalk to wash, followed by then using stalk a second time to do a wipe. Oh well.
But got me thinking, maybe I could splice in a toggle switch on the grey wire? Then, whenever I needed wash, I could toggle-on and use the stalk for a wash-and-wipe? Otherwise, keep it toggle-off, so I always maintain my access to wiper-only function? Any flaws or potential downsides you envision?
Thanks again, sir, as you saved me at least $107 for a dealer diagnostic, plus expectedly hundreds more for a fix. May ultimately end up surrendering to them for a fix, but in the meantime I have hope that, with your help, I can handle this myself for under $50 :-)
lopat08865 is offline   Reply With Quote
Old 03-11-2016, 07:57 PM   #2
Yes - Removing the grey will disable the washers, but if you want to still be able to use them on demand, until you figure out of the issue is gone with them disconnected, a toggle switch on the grey would do the trick.
Old 03-15-2016, 04:57 AM   #3
lopat08865
Rainy Monday morning drive to work in the dark makes me think problem *may* still have occurred.
Had the wipers on the whole trip, but after 50 miles driven the yellow "washer empty" light came on. What with the rain & the dark & the wipers going, I couldn't say for sure if the wash came on by itself?
DIY Cruise Control for 2012 Yaris - Good News! CTScott Third Gen Yaris General Discussion 306 08-02-2026 02:50 PM
2012 Yaris Sedan - Wiper Blade Sizes mcastill66 DIY / Maintenance / Service 1 02-04-2015 08:41 PM
Comparison Test: 2012 Toyota Yaris Vs. 2012 Toyota Prius c Yar Is Word Third Gen Yaris General Discussion 27 09-06-2012 11:37 PM
Rear wiper: EZ mod so it pulls back all the way joelitton Cosmetic Modifications (Exterior/Interior) 10 10-22-2008 10:30 AM
About hand wash and other methods.... zyovka Wash, Wax, Detailing, Exterior Repairs 5 09-27-2006 05:10 AM
