![]() Drives: Yaris Join Date: Jan 2016
Yes, but can the dealer replace it with a used one? I got a used one but no master key for it.
#2 | |
If you have a used one, I would just swap that part. Being a through-hole part it would be very easy to replace.
#3 | |
![]() Edit: Swapped out the two chips, no difference at all. Last edited by ATB; 03-12-2016 at 10:12 AM. |
#4 | |
OK. In that case the problem is likely with the micro controller that commands the driver. Unfortunately he is one of the large surface mount ICs.
| Passenger Door Stuck - Repair Options? | cry0 | DIY / Maintenance / Service | 3 | 07-27-2015 12:08 PM |
