#19 | |
Pumpman
Drives: 2019 Kia Soul EV Base Join Date: Dec 2014
"I would rather loose by a mile in a car I built myself, then win by an inch in a car that was built for me." - Moog |
#20 | |
#21 | |
I did another search and the only video I can find of this xB is 300 whp on a dyno in 2013. In that video he has 400whp as a daily driver. Another video back in 2011 is just a montage of pictures showing parts out of the box and some of the xB. Title says 500whp... no video of dyno or anything... ![]()
#22 |
Mr. 155 and climbing
The platform can handle over 400whp however not sure how long the c50 series can with OEM components. Chew's build has the vitz rs turbo 6 speed trans iirc. The latest 1nz build that I have seen that is hefty other than mine or Garm's is a guy from Paraguay however haven't heard what his transmission is and or whether or not it has upgraded gearing. As Jason has stated it really seems the end of the day will always have the synchros as the weakest link.
Sent from m-o-b-i-l-e
#23 |
![]() ![]() Drives: 1nzfe Join Date: Jan 2016
All done. Upgraded custom syncros.
#24 |
Yep, stick to that story.
I first started working with Ray in 2010 when we built our first Yaris, and we spent six months going back and forth (in 2012 when his shop was local to us) trying to make the first installations of the close-ratio set in the Yaris work. So upon hearing from you that there are upgraded custom synchros I had to reach out to him again - great time to do it since once of my Kaaz trans is being rebuilt. No surprise, you are full of it as usual. "There is no update on the gear set. Once the current inventory is gone, Kaaz will probably come up with a new set up. Gear set sales have been pretty good lately. We see more demand for the older cars now since many gearboxes out there running are all getting tired. Kaaz will probably make changes in design or the ratio when the new kit comes out. Hopefully it will use the later model synchro rings." I wont include the further commentary, I wouldn't want to further embarrass you. Kaaz states the trans will support around 200hp in racing conditions. Show cars and trailer queens may claim whatever they want - its not like anyone will ever see if the parts are even in there. Three years of racing use took its toll on the Celica parts used with the Kaaz gears:
#25 |
I drag race, completely different. On road course where your cornering and putting entirely more load than I am yes the transmission will only handle up to 300hp before failure. I've run stock stuff up to 523hp on the drag strip with zero failure. Ray had my entire gear box apart nothing hurt. So big difference between road course with huge load bearing turns and straight line.
#26 | |
Guess you were to busy posting pics of other peoples parts to make it to the drag strip, or at least show a pic of it. Nothing but bling and dyno bragging. https://www.facebook.com/One-Nz-Fe-R...73500/timeline
#27 |
You do your thing I'll do mine.
#28 |
iQ innovator & researcher
Drives: 2012 iQ Join Date: Mar 2016
#29 | |
#30 |
play every day
#31 |
![]() ![]() Drives: vitz rs Join Date: Apr 2011
U'r all the greatest.. super drag.. ultra racing.. my car is vitz rs (echo hatch) n/a deep tuned with Kaaz C60 close ratio 1st to 5th (I cut primary shaft)..
trd helical lsd.. Toyo R1R 195 50 15 semislick.. not more than 130hp.. I replaced engine mounts 2 times.. several clutches smashed like paper.. Ray Kaaz tells C56/C60 oem transmission takes 220hp.. gears he used with Scion Xd Rally Car C56 Kaaz close ratio (3rd-4th-5th) has been completely WPC treated, 1st , 2nd e final gear too. It had to take 265hp and often it blew up under rally abuse.. it all depends on how they drive.. I know if I go turbo doubling torque I destroy gearbox and shafts.. I used Kaaz 3..4..5 with Kaaz 4.6 final but I prefer all 5 bigger close gears.. tons of difference than oem gearbox.. it is much precise.. quick.. short ratio.. loud :) |
#32 |
Data doesn't lie
Drives: That Scrappy 2zrVios Join Date: Oct 2014
BUAHAHAHAHA
#33 |
![]() Drives: Yaris 1.3 Restyling Join Date: Oct 2012
I have c56 built by Ray some times ago.bought used from a friend, i was able to apply c154 housing and swap ot to my 2szfe.Superb gearbox for short track use.maybe the 4.6 final gear drive is too short but sit nicely with the races i do
| Dual 8’’ Cargo Floor Sub Box Build | Ataristyle | In Car Entertainment + Electronics (audio / video / alarm) | 18 | 03-23-2016 01:27 AM |
| views on comma gear box oil | sant_ashu | DIY / Maintenance / Service | 2 | 04-07-2013 11:33 PM |
| Sub Box Desgin | talnlnky | In Car Entertainment + Electronics (audio / video / alarm) | 5 | 08-23-2009 01:45 AM |
| RMS capabilities | Slick | In Car Entertainment + Electronics (audio / video / alarm) | 31 | 08-21-2009 09:52 PM |
| DIY: Custom Hidden Trunk Box (08 Yaris 3D) | goku87 | In Car Entertainment + Electronics (audio / video / alarm) | 0 | 10-19-2008 05:43 PM |
