![]() Drives: Yaris Join Date: Mar 2016
I found the solution to my problem.
On pin 1, black wire, plug right (power supply of meter after ignition) appeared voltage when the engine was turned off. 12 V when the plug was pulled out. 8-7 V when the plug is connected. Unfortunately, the power scheme does not agree with the "2007 Yaris Factory Repair Manual", probably because I have a start-stop system. I cut off the old wire and connected to pin 1 new wire supplied directly from the IG2 relay (15A fuse AM2). For now everything looks good. |
#2 | |
Do you have any aftermarket electrical system modifications?
| Zage Turbo Kit Install - Toyota Yaris | Focus_Sh1ft | Forced Induction Forum | 160 | 02-06-2022 08:14 PM |
| p2138 engine code | crazylegs | DIY / Maintenance / Service | 25 | 08-20-2020 05:40 AM |
| 1kr-fe engine wiring | boothybunch | DIY / Maintenance / Service | 0 | 03-28-2011 03:59 AM |
| Engine noise and Oil Lamp on | bieniman | DIY / Maintenance / Service | 21 | 12-12-2010 11:47 PM |
| Info regarding Engine change. | sheraz2000 | General Yaris / Vitz Discussion | 5 | 01-08-2009 12:51 AM |
