Old 03-21-2016, 02:55 PM   #1
klej89
Drives: Yaris
I do not have any modifications of the electrical system.
I know that on this pin should not be voltage with the engine off.
I have three basic problems:
1) On the back of the Instrument Panel J/B I have three sockets
https://onedrive.live.com/?cid=7E8AA...%21103&o=OneUp
In the schematic in the "2007 Yaris Factory Repair Manual" There are four sockets ...
2) I checked for continuity from pin 4 sockets 4F (Front Instrument Panel J/B) to pin 1 of a plug meter (MET 7.5A fuse was inserted) - there is no continuity (according to the scheme should be).
3) I can not remove the instrument panel because I can not unscrew the two bolts from the passenger air bag. For this reason, I do not have good access to Instrument Panel J/B and all the cables.
For these three reasons, at the moment I made a new wire to the power meter.
klej89 is offline   Reply With Quote
p2138 engine code crazylegs DIY / Maintenance / Service 25 08-20-2020 05:40 AM
1kr-fe engine wiring boothybunch DIY / Maintenance / Service 0 03-28-2011 03:59 AM
Engine noise and Oil Lamp on bieniman DIY / Maintenance / Service 21 12-12-2010 11:47 PM
Info regarding Engine change. sheraz2000 General Yaris / Vitz Discussion 5 01-08-2009 12:51 AM
