Old 03-24-2016, 05:15 PM   #1
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
If you can find the people who installed the alarm or the manufacturers ask them if the sensitivity can be adjusted.
Many alarm systems have movement sensors that are meant to trigger if an attempt is made to tow the car. If these are too sensitive, they can be set off by a gust of wind or even by a cat jumping on the car. There can also be Glass breakage detectors that are meant to trigger on the sound of a window being broken that can also be way too sensitive.
I used to live near Kingsford Smith (Sydney) airport, directly under the flight path. The sound of a jet taking off overhead would often trigger car alarms in the street.
Disable the stock (?) alarm so I can safely reconnect the battery frankienap In Car Entertainment + Electronics (audio / video / alarm) 3 01-19-2016 11:59 AM
How to disconnect the ALARM? junorico24 DIY / Maintenance / Service 3 12-13-2015 07:39 AM
Keep your vehicle protected! sqcomp In Car Entertainment + Electronics (audio / video / alarm) 17 09-10-2009 02:02 AM
How to disconnect horn from alarm ??? Yawesh General Yaris / Vitz Discussion 5 02-19-2009 06:12 PM
help me with my annoying alarm! misteo In Car Entertainment + Electronics (audio / video / alarm) 1 10-21-2008 01:49 PM
