Old 03-28-2016, 11:18 AM   #1
Kitt
Kitt's Avatar
Drives: Thndr cl metallic HB 3 drs '05
Send a message via MSN to Kitt
Originally Posted by ern-diz View Post
I had to have mine replaced at 40k, I suspect due to a friend backing into my car while parked behind her. Toyota did it, as I was still under extended warranty, and from what I understand they had to damn near pull the whole dash out, including steering assembly. Not 100% sure, again, since I didn't do it myself.
yep, that is the way the manual says it has to be done, but that's way too much complicated and time consuming. The rack ends are pretty much accessible, however, trying to remove them using a wrench is complicated due to the space, I guess that is why they remove the whole thing
20 years... alive and kickin'!!
Kitt is offline   Reply With Quote
Old 03-28-2016, 08:42 PM   #2
I have replaced bent ones on wrecked Yaris. It is actually not too bad to do in place. They come off easier than you would expect.
Old 12-29-2018, 02:34 PM   #3
kgoohs
Drives: 2009 Yaris
how difficult is it to replace a 2009 Yaris Rack? Working on it...
320K miles so far. going strong!
kgoohs is offline   Reply With Quote
Inner tie rod replacement - rack assembly? jwpaine DIY / Maintenance / Service 1 02-04-2015 07:22 PM
Replacement Radio + Steering Wheel Control Questions dinop In Car Entertainment + Electronics (audio / video / alarm) 0 07-07-2013 01:31 PM
OEM roof rack mounting rubber pad replacement Yai Cosmetic Modifications (Exterior/Interior) 3 12-22-2012 12:01 PM
The Yaris Steering Wheel wornways General Yaris / Vitz Discussion 12 10-09-2012 01:41 PM
Upgrade Steering rack bushings?? aeipee13 Performance Modifications 1 07-14-2009 02:17 PM
