Old 03-28-2016, 10:14 PM   #12
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
The roof lining (on my series 3) has one clip that needs to be popped out.
The cover on the rear side pillar can be popped off fairly easily like most other internal panels. you only need a big enough gap to get your hand inside the lining.
Use an old wire coat hanger straightened out, or a flexible plastic rod to go around the back window. Once you have fed it through, you can attach the cable from the camera to the end and draw it through.
it's best to remove the flexible rubber tube from the hatch, rather than the body when running through into the roof lining. poke the draw wire or rod back through the tube to pull the camera cable through into the roof. you can then easily get to the side and run down to the rear light assembly for power from the reversing light.
the plastic pieces along the bottom of the door frames holding the edges of the carpet lift off to give access to a wiring channel. you can use these to get the cable to the dashboard.
Install 2010 Front Grill in a 2008 Yaris Sedan dilandias General Yaris / Vitz Discussion 3 01-21-2016 10:37 PM
2010 yaris ? bigdoglover New YARIS Purchase Forum 0 01-01-2016 08:28 AM
