#37 |
![]() ![]() ![]() ![]() Drives: Thndr cl metallic HB 3 drs '05 Join Date: Mar 2006
I was checking my car's wiring and it has the wire and plug for each fog lamp in the front. It does not have the relay and ovbiously not the stalk. So, all I have to do is change the stalk, plug the relay and install the fog lamps?
20 years... alive and kickin'!! ![]()
#38 |
Theoretically that is correct. Was your car a Japanese market Vitz?
#39 |
I purchased it in Panama, AFAIK it is labeled by Toyota as general market, but it shares several parts. The stalk, for example, is the same.
#40 |
![]() Drives: 2012 Yaris Join Date: Aug 2013
The link is not working
#41 |
Correct. Unfortunately Micro Image has closed its doors. I am not aware of another plug and play aftermarket fog light kit for the Yaris.
#42 |
![]() Drives: Yaris 2012 sedan 4 doors Join Date: Mar 2016
Hello guys I'm new here I'm looking the fog light on eBay but I got confuse because I don't know which one should I get when I type my model which is Yaris 2012 sedan 4 dr. It shows fog light sedan 2006-2011 the other one says fog light for Yaris 2/5 dr hatch 2012-2015
I can easily pick the 2012 but I have the 4 dr sedan. |
#43 | |
#44 |
![]() Drives: 2010 Yaris Join Date: Mar 2016
CTScott are there still no good options for fog lights off the shelf (2010 hatchback) or is everything a piece together parts list ?
#45 |
I have not seen any good complete kits since MicroImage closed. I used to build the plug and play harnesses for them and can modify the crappy kits into the equivalent.
#46 | |
Based on the wiring diagragm and parts I was looking at, it looks to be a simpler install so long as i wire to the relay properly. |
#47 | |
The aftermarket kits are not actually designed for the car. There was a DIY on here about using the aftermarket kits with the OEM wiring, but the internal circuitry of the switch included with the kit bridges the switching and the illumination circuits together. Also the relay included with most aftermarket kits is garbage and many who have used it have eventually had it internally fail and melt its plastic case.
#48 |
I disassembled my eBay harness, bought the proper relay, and have everything wired inside the car (using switch) and got everything under the hood wired up.
Relay clicks, and one fog lights up pretty weakly. I believe I traced it to the connection to the under hood fuse panel, I don't think my wires are reaching the pins fully. I bought the pins below thinking they were the right kind, but they do not go all the way into the plug. Are these correct, or an I missing some trick to 'insert wire'? ![]() Edit: connection might be good, as I tried it without the plug and touched the pins directly. Still one light on weak and the other off. Either bad lights or I need to have a dedicated wire to each, as they are spliced further down. Odd I would expect both to be on weakly in that case Last edited by ercdvs; 04-22-2016 at 10:21 PM. |
#49 |
![]() Drives: Yaris Join Date: Aug 2016
#50 |
![]() Drives: 09 yaris sedan Barcelona Red Join Date: Mar 2011
Hey, just bought a nearly new 09 yaris sedan. Wondering if these look good to you? https://www.amazon.ca/gp/product/B01...F7G43XA2&psc=1
#51 |
![]() ![]() Drives: 2010 Yaris Join Date: Jan 2010
I just bought THIS kit on Amazon.
It seems decent and I will be wiring similar to a factory set up. I just made a minor mod to the wiring that came with the lights. The power wire to both lights were spliced together, I cut the splice so that each light is independent of the other. The two wires will be plugged into the underhood fuse panel.
The moving power of mathematical invention is not reasoning but imagination. Augustus de Morgan Truth does not change because it is, or is not, believed by a majority of the people. Giordano Bruno |
#52 |
OK many aftermarket Fog Light Kits will work with the factory wiring. A few things need to be fixed in the kit I used.
1. The wiring from the right fog light ties into the left. I separated the wires so that each light has its own wires. 2. The Toyota relay is not necessary. A Denso 567-0001 relay is readily available and inexpensive and WILL work. 3. In the directions found here, the aftermarket switch MUST be modified to work with the factory wiring. Simply remove the resistor indicated in the directions. Also in my kit, two of the switch wires were tied together. I separated them. One pair to lighting, the other pair to the headlight switch wiring. 4. The wires to plug into the outside fuse block, any reputable car audio shop can make the ends with the right connector on it. Fog Lights I used worked perfectly.
#53 |
OK I want to finish this up.
The wires to plug into the outside fuse block, any reputable car audio shop can make the ends with the right connector on it. In fact, for the two wires with the ends crimped on them was a total of $4.76. The owner was intrigued. In exchange for explaining exactly what I had done, he loaned me a portable soldering iron, gave me a couple pieces of heat shrink and let me finish it there in his parking lot. ![]() Anyway its finished and it works
#54 |
![]() Drives: 2009 Toyota Yaris Sedan Join Date: Jun 2017
Very informative! Thank you very much.
| Fog Light wiring | Rammy | DIY / Maintenance / Service | 0 | 11-08-2012 08:34 PM |
| viene viene FOG LIGHT IN Da HOUSE!!! | toro yaris pr | Caribbean | 27 | 07-18-2010 04:50 PM |
| My Yaris Fog Light | ezlove0710 | DIY / Maintenance / Service | 7 | 08-07-2009 06:15 PM |
| DIY:Day time running light Disabled with stock fog light remain function | summergxz | DIY / Maintenance / Service | 12 | 09-26-2007 10:42 AM |
