Old 04-09-2016, 11:01 AM   #1
tmontague
tmontague's Avatar
Use MAF cleaner to clean it. This can be found at a local auto parts store.
Easiest way to check for vacuum leaks is to use your scanner and view long and short term fuel trims. If the values drastically change under 2500rpm compared to idle then it's likely a vacuum leak.
Use an incense stick to find where the leak is. It is likely due to one of these 2 issues.
I don't know how vacuum would ever get to -1.5, technically that is going into boost which is impossible in a non boosted car regardless of a vacuum leak or not. (somone correct me if i'm wrong)
Old 04-09-2016, 11:06 AM   #2
z0mb13k1ll
z0mb13k1ll's Avatar
Drives: '15 Dodge Challenger
Originally Posted by tmontague View Post
Use MAF cleaner to clean it. This can be found at a local auto parts store.)
I will pick some up today on my way home and see if that does the trick, hopefully i can get the MAF sensor off easily as it is now very close to the battery on the back side of the pipe
I was unsure how i was getting readings below 0 as well, but that is the info i was picking up from torque at least.
z0mb13k1ll is offline   Reply With Quote
Tags
check engine light, cold air intake, sedan
Blitz Super Charger - Switch Issues AzianCuz Forced Induction Forum 21 08-25-2015 09:59 PM
DC Sports CAI interference problem with fog lights beaker Performance Modifications 5 09-15-2014 07:26 PM
DC header, AEM cai and MI lightweight crank pulley install aspro Performance Modifications 7 09-02-2014 06:57 AM
New aFe CAI = CEL with P0101 Error randydid Third Gen Yaris General Discussion 10 01-16-2012 10:24 PM
FS: BOMZ CAI posaunemeister Items for Sale by private party 8 10-03-2009 02:02 PM
