Old 04-11-2016, 10:18 PM   #4
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Originally Posted by jamesxl View Post
I need to replace my front drive axle as my CV boot had a tear in it. My buddy said that I needed to grab some transmission fluid as when I remove the drive axle the transmission fluid will leak out.
There in lies my question. I have a Yaris 2008 Manual transmission and when I check the owner's manual I see:
What is the oil that I would need in case the fluid leaks out? GL-4 or GL-5? or do I need SAE J1703 or FMVSS No. 116 DOT 3(or is this between the clutch pedal and the clutch)?
75 90 , plus you will loose lots makes a mess , suggestion drain first ...trust me i forgot when did mine ( new axle ) and god did it make a mess on the shop floor lol
Tags
cv joint, drive axle, replacement
Gearbox oil for multimode transmission. matanfr DIY / Maintenance / Service 1 08-16-2010 04:23 PM
Gear oil change choices (Canadians) Jem_hadar DIY / Maintenance / Service 17 08-29-2009 11:51 AM
Compiled 1NZFE Used Oil Analysis craigq DIY / Maintenance / Service 7 09-10-2007 04:27 PM
Motor oil debate - interesting info but a long read. mikeukrainetz General Yaris / Vitz Discussion 6 12-10-2006 08:16 PM
