0-60 in slow
FWD cars do that. Changing the suspension to stop it will only make the car handle worse. Since that tire is unloaded its really not contributing much to grip anyway.
2014 BSpec Divisional Champion |
![]() Drives: d4d Join Date: Sep 2010
Because the side walls of the tire are harder than normal tires, it provides a better feeling but not less grip. Basically R1R are excellent in handling. Is that what you meant by "unloaded"?
#3 | |
0-60 in slow
The other issue that "could" be at play, is stability control is apply brakes to the rear of the car which will also cause a rear tire to lift. Rear suspension generally has quite a bit of anti-lift built into it, so when torque is applied to the suspension(hitting the brakes) the rear of the car will want to squat down. A easy way to test this is to put the ebrake on and gently try to move forward, you'll feel the rear squat down. I don't fight rear tire lift on my road race car, its generally just something you have to deal with on FWD cars.
#4 | ||
So one solution, which dragoonmc suggested, is to upgrade the front sway bar. What do you think will happen if I buy a proper coilover (bilstein pss) or kyg agx with eibach springs? I believe that the front outer suspension will have less compression than the stock one, so the rear will be lift less, so the inner rear wheel may not lift at all, so the traction control will not be activated. Do you agree or not? please elaborate. Last edited by cyberguy; 04-15-2016 at 06:02 AM. |
![]() Drives: 08 yaris 1.8 dual vvti 5sp Join Date: Feb 2010
How long have you had it on.?Some of the newer systems have a learning ability,so you might have to drive it for a little while before it becomes less
intrusive and learns how you drive.But it might just mean that you are pushing the car to the limit and it is detecting a bigger slip angle between your input and what the car is actually doing.(under steering)I would try a rear sway bar on the rear so the back loses traction first ,canceling the under steer.Right now it seems like your front tires are losing traction first causing a under steer issue , meaning you are turning the steering wheel more to compensate and make the car turn the direction you want to go.By adding just a front sway bar you just adding to this problem by making the front tires lose traction even faster . |
#6 | |
The problem exists because the inner rear wheel is raised from the ground and the traction control is activated due to the difference of rotation between the two rear wheels. I am certain of this, as I have even installed a gopro in order to verify it. Of course this does not happen in normal driving but not in extreme conditions too. If for example normal speed for a turn is 90km/h and extreme speed is 140km/h, the issue appears at 100-110km/h |
| Got a free turbo and bad ideas | xnamerxx | Forced Induction Forum | 4 | 09-25-2013 11:35 AM |
| Want to customize, but don't know where to start....Any relatively cheap ideas? | JerseyJeff84 | Cosmetic Modifications (Exterior/Interior) | 28 | 07-17-2011 12:06 PM |
| New Yaris owner, any mod ideas? | geniusmusicman | General Yaris / Vitz Discussion | 16 | 01-28-2010 10:53 PM |
| Meet Ideas | Adriaan | Canada | 0 | 05-16-2009 11:37 PM |
| Valentines Day Gift Ideas! | YarisSedan | Off-topic / Other Cars / Everything else Discussions | 14 | 02-10-2009 10:05 AM |
