Old 04-15-2016, 11:57 AM   #1
froger
Drives: 08 yaris 1.8 dual vvti 5sp
How long have you had it on.?Some of the newer systems have a learning ability,so you might have to drive it for a little while before it becomes less
intrusive and learns how you drive.But it might just mean that you are pushing the car to the limit and it is detecting a bigger slip angle between your input and what the car is actually doing.(under steering)I would try a rear sway bar on the rear so the back loses traction first ,canceling the under steer.Right now it seems like your front tires are losing traction first causing a under steer issue , meaning you are turning the steering wheel more to compensate and make the car turn the direction you want to go.By adding just a front sway bar you just adding to this problem by making the front tires lose traction even faster .
froger is offline   Reply With Quote
Old 04-15-2016, 06:08 PM   #2
cyberguy
Drives: d4d
Unfortunately the traction control does not have any learning capabilities. I have been racing for many years now and when I say that the car does not understeer I am certain 100%.
The problem exists because the inner rear wheel is raised from the ground and the traction control is activated due to the difference of rotation between the two rear wheels. I am certain of this, as I have even installed a gopro in order to verify it. Of course this does not happen in normal driving but not in extreme conditions too. If for example normal speed for a turn is 90km/h and extreme speed is 140km/h, the issue appears at 100-110km/h
cyberguy is offline   Reply With Quote
Got a free turbo and bad ideas xnamerxx Forced Induction Forum 4 09-25-2013 11:35 AM
Want to customize, but don't know where to start....Any relatively cheap ideas? JerseyJeff84 Cosmetic Modifications (Exterior/Interior) 28 07-17-2011 12:06 PM
New Yaris owner, any mod ideas? geniusmusicman General Yaris / Vitz Discussion 16 01-28-2010 10:53 PM
Meet Ideas Adriaan Canada 0 05-16-2009 11:37 PM
Valentines Day Gift Ideas! YarisSedan Off-topic / Other Cars / Everything else Discussions 14 02-10-2009 10:05 AM
