![]() Drives: 11 GSE21, 86 AE86 Join Date: Apr 2016
The ZSP90 used the same clutch master cylinder with the C56 and EC67.
If you bought an EC67 and it didn't come with any of the hydraulics, the following parts are what you'd need: 31400-59015 - Cylinder, Slave (with integrated release hub, includes bolts) 31407-52010 - Bleeder, Clutch Slave 91551-80820 - Bolt, Clutch Slave Bleeder (Qty: 2) 31482-52090 - Tube, Clutch (Slave to Bleeder) 31126-20090 - Boot, Clutch Tube 31482-52100 - Tube, Clutch Bleeder to Flexible Hose 90461-08567 - Clamp, Bleeder to Hose Tube 31484-52160 - Bracket, Tube to Hose (Transmission Side) 91671-80810 - Bolt, Tube and Bracket (Qty: 2) 90947-02G28 - Hose, Transmission to Body Everything on the body side is the same between the C56 and EC67. There are LH mount differences as well, however the RH/rear mounts are the same for C56 and EC67. The axles are the same between the two as well. 12372-37141 - Mount, RH Side 12325-37100 - Bracket, RH Mount 12351-37100 - Damper, RH Mount Jeff
![]() 2011 Lexus IS350 6MT F-Sport with LSD 1986 Toyota Corolla GT-S Supercharged with TRD Stuff 2005 Toyota Yaris RS 5MT Short Track Car |
| unusual engine swap | CoryM | Performance Modifications | 26 | 10-09-2015 12:17 AM |
| ***How to Choose an Exhaust System*** | Hussain-Vtec | Performance Modifications | 16 | 03-16-2014 08:02 AM |
| engine swap | djhuddy2442 | Performance Modifications | 6 | 04-11-2013 01:05 AM |
| Boost Gets U Laid eh? Count me In | yaris2010RS | Forced Induction Forum | 128 | 02-02-2013 04:57 PM |
| Scion/Yaris engine swap | mrrock | Performance Modifications | 1 | 03-02-2011 06:56 PM |
