Old 04-29-2016, 05:25 PM   #2
tmontague
tmontague's Avatar
There is a large 1-2" diameter black rubber cover right behind the battery. The large wiring harness goes through it into the cabin. You can barely see if but you can pierce it with a coat hanger and when the coatr hanger it half way through tape your wires to it and pull the coat hanger from the cabin. The hanger will come in above the clutch pedal.
I did this for my gauges and it was fine. The pita is to find it and get the coat hanger through it when you've never done it before. I'd avoid drilling if possible
Hole in my Exhaust? Losing Coolant? Peloton DIY / Maintenance / Service 7 02-02-2015 07:51 PM
What's this hole in my air intake? Yury General Yaris / Vitz Discussion 22 01-23-2012 07:00 PM
Drill hole in Driver's glovebox? Revsson In Car Entertainment + Electronics (audio / video / alarm) 6 07-05-2010 05:26 PM
Screwdriver popped a hole behour General Yaris / Vitz Discussion 5 01-30-2010 08:05 PM
Firewall!! plushDJ In Car Entertainment + Electronics (audio / video / alarm) 7 06-01-2006 12:20 AM
