![]() ![]() Drives: yaris 2005 Join Date: Mar 2016
Air Conditioning Problem
Gents
Problem : AC is not blowing cold air AC lights on Blower fan working setting 1 2 3 4 all different speed Visually checked compressor at the belt / pulleys Cabin filtre replaced (blower motor is under this) Can anyone suggest any other thing I need to check |
Probably best to take it to the shop. You've either got a leak and the system is out of or low on refrigerant, or the compressor is shot.
![]() ![]() ![]() Drives: 2006 Yaris RS 3-Door Join Date: Feb 2016
I think i am in agreement with u its low on refrigerant.
Could also be, but probably not, a failure in the coolant line pressure sensor. If this sensor has failed, or is sending a low pressure signal, the compressor will not kick in.
Can u pls upload a pic where it is how can i check
Update
Recharge the gas and its now ok. Thanks All |
Where's it leaking from?
Mech said no leaks
Uh oh you might have the problem all over again if the lack of fluid was because of a leak.
All over ?
Car req recharge every 2-3 year
Really? My car is 7 years old and my wife's is nearly 12 years old and the ac works and has never been recharged.
#14 |
#15 |
Air Conditioning Re-Gas
It is recommended that you should recharge your air conditioning system every 2 years with gas and lubricant, in order to keep it running efficiently. This is not included as part of a routine car service and so it can often be overlooked. If your car is more than 2 years old it is more than likely due a re-gas. This service ensures that your air conditioning system is working efficiently by testing the gas pressure to see if it has dropped. A drop in gas pressure will result in a loss of cooling efficiency which will make your engine work harder and in turn use more fuel. Due to it's dehumidifying properties, when operating fully efficiently, your air conditioning system will also de-mist your windscreen more rapidly in cold weather. Login & Quick Reply |
#16 |
Now thats my understanding
#17 |
Happy to correct myself
#18 |
| Need help troubleshooting air conditioning | davislau | DIY / Maintenance / Service | 7 | 07-15-2015 11:54 AM |
| air circulation fan problem | tomdf | DIY / Maintenance / Service | 8 | 12-10-2012 07:53 AM |
| Air conditioning Blower | satdan | DIY / Maintenance / Service | 1 | 09-13-2012 03:13 PM |
| max air conditioning button | Idahotom | General Yaris / Vitz Discussion | 0 | 07-06-2011 10:41 PM |
| air conditioning | markpeppie | General Yaris / Vitz Discussion | 34 | 06-20-2006 02:17 PM |
