Old 05-12-2016, 05:43 PM   #1
CoryM
Drives: 2009 5-door, 5-speed
Originally Posted by Jason@SportsCar View Post
Swaybars build grip on the opposite end of the car they are attached to. They do this by providing a lifting force to the inside tire - as the outside tire compresses the swaybar transfers the load and pushes the connected tire in the same direction. You are in fact reducing grip on the axle the bar is attached to.
Swaybars in general are a crutch for a poorly tuned suspension. That said, you are limited in HS with the mods you can do, and one of them wont be fixing the lack of spring rate, so you do what you can. In a fwd car the last thing I want to do is remove front grip, and that is what a bigger front bar is doing.
I would go the other way and find a way to transfer as much grip from the rear of the car to the front. Go with a bigger rear bar, or get a set of proper rear shocks that will help suck up that back tire quicker, forcing grip to the front.
In our car we dont even run a rear bar, just droop limiters in the rear shocks that pick the back tire up almost instantly.
That way of thinking is definitely the right path for the vast majority of FWD cars. This is why I waited so long to try a front bar on my car. Where the traditional way of thinking goes wrong is Stock class when the CG is high and/or springs are too soft. High body roll, high neg camber and struts cause the inside front tire to lose a large amount of contact patch. In my car I was losing ~1/2 of my inside F tire contact patch. That's a lot of rubber, and it shows everytime I try to accell out of an element.
Yes the F bar loses grip by transferring weight to the rear, but it also gains grip by almost doubling the contact patch of the inside F tire (and gains a little outside F contact patch due to reduced pressures). Is this enough to net more F grip over all? No idea, but it sure feels like it. If I had the tire-curve, I could do a bunch of measurements and math to figure out which gains more grip (on paper). In practice, it would take a serious test and tune session to confirm one way or the other.
Again, this pretty much only applies to HS cars and maybe only over-tired HS cars. It's possible it needs R-comps to see gains, and maybe this winter running my street/wet tires will show the front bar to be detrimental.
Old 05-12-2016, 05:58 PM   #2
Jason@SportsCar
Not sure who sold you on that, but if you like it go with it.
Old 05-12-2016, 07:59 PM   #3
invader166
Pumpman
Drives: 2019 Kia Soul EV Base
Hmmm...your OP states that you have Tokico blues installed? I've heard they are a pretty stiff shock. Why not try some softer shocks with the front bar? That way, maybe you can load and unload your tires at a faster rate and be able to further increase your tire contact with the road.
Just another idea, but like you stated above. No way to really find out without some serious tests, and proper math.
"I would rather loose by a mile in a car I built myself, then win by an inch in a car that was built for me." - Moog
invader166 is offline   Reply With Quote
Old 05-14-2016, 01:50 PM   #4
CoryM
I could definitely do better in the shock department. I'm not sure what the blues are intended for, but stock springs is not it. I only got them because I needed something to replace a damaged OE strut. The Yaris only gets new parts when it *needs* them. The whole point of me driving the economical car is to spend less on it so I can spend more on faster cars . This is also why I've stayed in HS as it reduces the temptation to buy stuff for the little car.
Cheers.
budget B Spec rally build slowly coming along 07dirtyaris Tracking, Racing, Auto-X Forum 8 08-15-2016 04:21 PM
1NZ-FE All Motor Build burned Performance Modifications 19 10-24-2014 10:56 AM
Turbo build - stage 1:D abstractmethod Forced Induction Forum 21 03-13-2014 08:04 AM
Carbon build up in the throttle body Sedan DIY / Maintenance / Service 18 11-15-2013 11:44 PM
