Old 05-17-2016, 07:03 PM   #1
tmontague
tmontague's Avatar
IMO stick with conventional or you're just burning money. In a high mileage vehicle like yours that doesn't see freezing temps there is no benefit. Dyno oil lubricates just as well as conventional in your climate.
I do run syn oil in my Echo that has 380k km on it but that is only in the few crazy cold months during the winter since it doesn't start as smoothly as it once used to. Once the temp rise I go back to conventional. FWIW I do notice slightly more oil loss with the syn oil, and the weight is always 5w30.
It burns about 1L every 1000-1500 km so I don't bother doing oil changes anymore, just the filter.
You may find adding an additive like syn lube or similar helps with the oil burning. It makes a big difference in my Echo, I suppose you could also just run a heavier weight oil as well.
I just find it hard to believe that this amount of oil burning just happened all of a sudden. This point to you needing to check the PCV, that said it could just be a beaten on enigne with failing rings.
Old 05-17-2016, 07:55 PM   #2
Ramon1691
Ramon1691's Avatar
Drives: 2007 Yaris hatchback
In only went down a few lines like 3 or so a little down from the full mark I have after 1800 miles with the synthetic also I don't know whether the previous owner kept up with the oil changes that well when I bought it I did a whole tune up on it I'm just going to stick to conventional as you mentioned and just going to keep an eye on the oil every month or so I had my mechanic check the pcv valve and it was good I seen this cars last many miles I also got my serpentine belt done that bastard was full of cracks :/
Ramon1691 is offline   Reply With Quote
Checking oil in the Yaris jb48 General Yaris / Vitz Discussion 16 09-15-2015 04:15 PM
Question replacing head gasket. Snyprwlf47 DIY / Maintenance / Service 3 07-13-2014 11:17 PM
Comparison Test: 2012 Toyota Yaris Vs. 2012 Toyota Prius c Yar Is Word Third Gen Yaris General Discussion 27 09-06-2012 11:37 PM
Did they increase the oil capacity for 09 Yaris? 2007yariz DIY / Maintenance / Service 8 05-18-2011 09:28 PM
