Old 05-17-2016, 10:53 PM   #1
UberSilver
UberSilver's Avatar
Drives: 08Yaris2D, 88LandCruiser.
This stuff slowed my Land cruiser from burning oil.
http://www.walmart.com/ip/17018131?w...787248&veh=sem
Give a man a fish, and he'll eat for a day. Sell a man a fish, and you'll both eat for a day.
UberSilver is offline   Reply With Quote
Old 05-18-2016, 01:30 AM   #2
tarkus
tarkus's Avatar
Drives: 2006 Yaris RS 3-Door
Originally Posted by tmontague View Post
In a high mileage vehicle like yours that doesn't see freezing temps there is no benefit.
I just find it hard to believe that this amount of oil burning just happened all of a sudden.
Synthetic still reduces friction wear, regardless of the weather. However, I take your point that if the car is just burning up the oil, you might as well use the cheaper stuff. Like you. I also think it's odd that the car just suddenly started burning oil, and I think that should be looked into.
That's exactly what I would recommend, once the underlying issue has been figured out.
Sent from my LG-D801 using Tapatalk
tarkus is offline   Reply With Quote
Old 05-18-2016, 11:28 AM   #3
Ramon1691
Ramon1691's Avatar
Drives: 2007 Yaris hatchback
Thank you TARKUS I will use that high Milage oil on my next oil change for now I'll just keep an eye on my oil level since I put conventional back in tho when I changed from the synthetic I noticed that it was really dirty with only 1800 miles on the oil is that normal? Maybe it was all the crap build up on the engine I'm not mechanically inclined but I don't see any leaks underneath or around the motor either
Ramon1691 is offline   Reply With Quote
Checking oil in the Yaris jb48 General Yaris / Vitz Discussion 16 09-15-2015 04:15 PM
Question replacing head gasket. Snyprwlf47 DIY / Maintenance / Service 3 07-13-2014 11:17 PM
Comparison Test: 2012 Toyota Yaris Vs. 2012 Toyota Prius c Yar Is Word Third Gen Yaris General Discussion 27 09-06-2012 11:37 PM
Did they increase the oil capacity for 09 Yaris? 2007yariz DIY / Maintenance / Service 8 05-18-2011 09:28 PM
