Old 05-24-2016, 03:41 PM   #1
sang pengembara
sang pengembara's Avatar
Drives: Y-sedan'07-1nzfe engine swap
I hope there is some slots to install this Pistons ASAP...
Sent from my C6903 using Tapatalk
sang pengembara is offline   Reply With Quote
Old 06-11-2016, 01:51 AM   #2
rabbito
rabbito's Avatar
Drives: 2012 Toyota Yaris Sedan (Vios)
please update for us...did you install them yet? i heard you also need new set of piston rings...updateeeeeeeee 😬😬😬😬😬😬
Sent from my SM-J700F using Tapatalk
Brain: ATD E85 Timing Advance ECU
Engine: 1JZ Injectors, Header, Center Pipe, K&N Drop In, E85 Injector Converter
Suspension: Hankook Tires, Performance OEM replacement Shocks & Springs F: 1.5 B: 1.4, Mu Spec brake pads, Front tower & Rear sway bars, Rays nut & lock
Electric: Volt Stablizer & Multi gauge obd2
Cosmetic: Toyota red emblem
rabbito is offline   Reply With Quote
Power-to-Weight Ratios of Yaris, Fit, Mini, etc. Idjiit Off-topic / Other Cars / Everything else Discussions 6 10-06-2017 05:10 PM
test drove a fit...mirage...and a yaris 428CobraJet Third Gen Yaris General Discussion 15 05-17-2015 02:08 PM
On tire pressures, the Yaris, and the Prius sbergman27 Fuel Economy Forum 18 04-05-2010 05:35 PM
