Old 05-28-2016, 12:22 AM   #1
B.B._07
Drives: 07 5dr
Looking up the codes I found:
P0722 Output Speed Sensor Circuit No Signal
P2767 TOYOTA - Input/Turbine Speed Sensor 'B' Circuit No Signal
So looks like the speed sensor is getting no signal in or out. The three wires should be 12 power, a pulse waveform output, and a ground wire. I would check the connector to the speed sensor for a loose connection or corrosion. You can check 12 power wire and ground wire quite easily with a test light or a multimeter
