Old 05-30-2016, 11:24 PM   #1
B.B._07
Drives: 07 5dr
Originally Posted by costica View Post
You don't understand. I can't rotate the copied key in the ignition switch. Copied key works only in the driver door. The original Toyota key work fine in ingnition switch and driver door.
The issue you're having is that the key is not cut well enough so it will work on one lock but not on all locks in the car. You need to take it back to where you got it cut to see if it's possible to get it fixed. It's a common issue with poorly cut keys or keys duplicated from well worn keys. When I bought my 07 it only came with one really worn key that I tried to have copied which resulted in a key that only worked in the ignition on one side and in none of the other locks.
Also in a 2013 Yaris you will need a key with an immobilizer chip that needs to be programmed otherwise even if the key turns in the ignition it will not start the car. You don't have to go to a dealer but you're options for programming are a dealer, a professional locksmith, or somebody that has access to Techstream software (and the cable).
2013 Black Toyota Yaris LE - 51000 odo tyta4lfe Cars for Sale by private party 1 08-23-2016 11:41 PM
Toyota Yaris 2013 with Touch and Go intercar In Car Entertainment + Electronics (audio / video / alarm) 0 10-29-2015 08:51 AM
Recent Toyota Yaris recall " electric steering" marcus DIY / Maintenance / Service 6 07-10-2013 03:30 PM
