Old 06-02-2016, 07:58 PM   #1
NotAMechanic
Drives: 2007
So do I need to change just the blower motor or are there other parts that should be changed, too?
NotAMechanic is offline   Reply With Quote
Old 06-02-2016, 08:33 PM   #2
First check the 40A HTR fuse, which is on the face of the under dash fuse panel.
There is also the blower resistor assembly, which is the rectangular metal piece mounted to the fan housing next to the fan. If it goes bad the fan will not run. It can be checked with a multimeter.
Finally, if those are both good, pull the fan and check it with the multimeter as well.
A/C suddenly quit ktb973 DIY / Maintenance / Service 13 07-10-2011 08:08 PM
How to quit your job online tomato Off-topic / Other Cars / Everything else Discussions 17 08-13-2010 03:18 AM
My horn quit - not the fuse. m3ga_band_g33k DIY / Maintenance / Service 2 12-07-2009 07:11 PM
quit smoking how long does it take to .... marcus Off-topic / Other Cars / Everything else Discussions 14 11-12-2008 08:20 PM
Buy a Yaris, Quit Smoking Typer73 Off-topic / Other Cars / Everything else Discussions 36 05-02-2007 07:24 PM
