Old 06-16-2016, 12:43 AM   #1
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
No, if I did the racing you did, I'd be swapping in rear disc. Though, I already did that.
Old 06-16-2016, 12:48 AM   #2
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
There has been plenty of discussions within the LSR community about rear drums and most keep them.
Sent from m-o-b-i-l-e
Old 06-16-2016, 07:53 AM   #3
Bluevitz-rs
I would think that disc carry far less weight, especially at their outer edge and would lower rotating mass and improve acceleration
Old 06-17-2016, 01:04 AM   #4
fnkngrv
fnkngrv's Avatar
There have been a few guys that I have talked to that have made the change and they really didn't notice any difference when it came to speed or acceleration. Braking yes, but that is because they went not only disc, by also big brake. To me the cost being several hundred to upwards of a grand isn't worth it. Time will tell.
Old 06-16-2016, 10:07 AM   #5
LTHatch
Drives: 2013 Yaris Hatchback L
How crazy are you going to go with that cage?
LTHatch is offline   Reply With Quote
Old 06-17-2016, 01:10 AM   #6
fnkngrv
fnkngrv's Avatar
It has to be a six point for up to 175. Over that will require a full. This one will have the main hoop, harness bar, front and rear legs. Depending I may go with a mid hoop angle leg however that isn't likely at this stage.
It should look something like this:
Old 06-18-2016, 10:12 AM   #7
Bluevitz-rs
The cage doesn't require a diagonal section across the main hoop?
Old 06-18-2016, 12:11 PM   #8
fnkngrv
fnkngrv's Avatar
Every chassis is different on what they require. That above is just an example they provide. The cage design actually requires approval.
Old 06-19-2016, 07:58 AM   #9
LTHatch
Pretty good, did you get the chance to re-tune for even more power?
Old 06-19-2016, 08:01 AM   #10
fnkngrv
fnkngrv's Avatar
Not yet and may end up being on the fly if I do get to race in a month. Too much to get done and getting to the Dyno is tough as it is. Plans may be shifting some as the house just went under contract yesterday, but the goal is to still race in July and LDW.
Old 06-21-2016, 01:14 AM   #11
fnkngrv
fnkngrv's Avatar
Kill switch and associated wire ordered. Also ordered a hood pin/cable set as well.
Old 06-22-2016, 08:43 PM   #12
fnkngrv
fnkngrv's Avatar
Hood pins arrived
Old 06-22-2016, 08:54 PM   #13
Bluevitz-rs
Just curious, how much is a good pin set like that?
Old 06-22-2016, 09:37 PM   #14
fnkngrv
fnkngrv's Avatar
Surprisingly cheap:
$19 with free prime shipping in the US
Old 06-24-2016, 02:50 PM   #15
fnkngrv
fnkngrv's Avatar
Kill switch and additional wire he arrived.
Old 08-03-2016, 10:53 PM   #16
fnkngrv
fnkngrv's Avatar
Been a while again. Been super busy with selling the house and getting ready to move to Texas.
Roll cage complete. Now to paint. Cage is 100% removable as well. 1 3/4" @ .120 sidewall. Good for up to 200mph. Then would need to go full cage then.
Old 08-09-2016, 10:55 AM   #17
LTHatch
Completely removable, so i assume you're going to bolt it into the car? That sounds almost insane a bolt in cage is rated to that speed, it looks damn good as always.
Hows the comfort of that Kirkey seat? You know you mean business when you have 10+ c16 5 gal tanks sitting in your garage lol
Old 08-09-2016, 11:22 AM   #18
fnkngrv
fnkngrv's Avatar
The cage has the 3/8" thick 6*6 top plats and then 3/8" 6*12 plates under the car. It is a standard setup for many subcompact cars out there. If I seem to have much more speed available then I will most likely go weld in because it will require me to upgrade to a full cage.
We use a ton of fuel each weekend. Carl's Mustang goes through 3-4 gallons alone per pass. Back in 2014 with the previous setup at 15psi I went through a half gallon per pass.
New 2016 SE and I need some help. VaultTec Third Gen Yaris General Discussion 7 05-10-2016 06:38 PM
TTR Yaris Turbo 2015 Updates fnkngrv Forced Induction Forum 199 05-07-2016 09:54 PM
April 17th Sunday Mosport DDT lapping event 10:30am-5pm #1 event Touge.ca 25+ 2016!! Touge.ca Canada 3 04-21-2016 02:40 PM
Touge.ca 2016 Track lapping events schedule - 25+ events 2016! Touge.ca Canada 0 03-23-2016 04:15 PM
EPA 2016 fuel economy manual reported a 2016 Yaris 6MT. matti Third Gen Yaris General Discussion 7 01-17-2016 07:15 AM
