Old 06-11-2016, 07:52 AM   #1
nkaufman
Drives: Yaris
Originally Posted by Biginjapan13 View Post
A drive belt is NOT an item that can be given a time or mileage time stamp. Living in Arizona I see drive belts start cracking at 45k miles. Visually inspect the drive belt and if there are cracks closer then 1 inch apart then the drive belt should be replaced. Just because there isn't a noise doesn't mean the belt isn't bad. The last thing you want is to be driving and the belt break cause then your engine won't have any accessories moving including the water pump
That is the reason for the post. If not based time or mileage criteria, then I thought noise would be the first indicator. Are you saying that the belt could snap just like that without presenting any symptom first?
nkaufman is offline   Reply With Quote
Old 06-11-2016, 09:45 AM   #2
Biginjapan13
Drives: lowered/ exhaust
Usually belts do make noise when they go bad, but there are sometimes that they don't. You said it didn't make noise when Turing the steering wheel but if I'm not mistaken you car has electronic power steering and there is no power steering pump. So even with a bad belt turning the wheel wouldn't create a noise with the belt anyhow. On the other hand just because it makes noise doesn't mean it's bad. A Yaris does not have an automatic tensioner and it the belt were to be loose (they can stretch) that could also make noise. If you could post a pic of the ribs on the drive belt I'm sure we could tell you if it's bad or not
Biginjapan13 is offline   Reply With Quote
Old 07-04-2016, 01:16 PM   #3
nkaufman
Drives: Yaris
Belt pics
Hello,
Attached are some pics. Do not know if I captured the condition of the belt properly enough. Please let me know.
Drive Belt replacement nkaufman DIY / Maintenance / Service 6 03-14-2015 02:13 PM
Drive Belt Replacement wagon DIY / Maintenance / Service 2 12-28-2014 11:24 AM
OCV or VVTI Solenoid.. Drive Belt Change Yar Is Thy Name DIY / Maintenance / Service 9 12-12-2014 12:44 PM
Increased ground clearance between 2008 and 2010 Sedan unclenefeesa Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 01-17-2013 05:49 AM
