Old 06-13-2016, 09:54 PM   #1
Originally Posted by Bluevitz-rs View Post
why don't you just rewire so the park bulbs are used instead of the main lights for your DRLs
how do you disable DRL's on the echo? is it as easy as unplugging the DRL relay like the yaris?
while i like the idea of parking light DRL, it IS easier to just unplug the DRL module and turn on the lights when you need them....unless you have an RS yaris with factory fogs
Old 06-13-2016, 11:32 PM   #2
IllusionX
Drives: 07 Yaris Sedan Aero
Adam, i believe the DRL module works exactly the same as the one found in the Yaris. You have one wire that will activate the low beam on a pulse. Just take that and tap it to the light you want to turn on as DRL..
If you unplug the module, you will lose the handbrake light on the dash.
Sent from my ONE A2005 using Tapatalk
Old 06-14-2016, 05:54 AM   #3
lose the ebrake light? thats odd...
Old 06-14-2016, 06:46 AM   #4
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
It's fine on mine, light still there.
Old 06-14-2016, 09:45 AM   #5
IllusionX
Barber got an echo. The only thing that affects the Yaris is the fog lights. Just tap the orange wire to ground. For me, I modified the relay box to turn on the fogs as DRL. It's the big blue wire that I wired up to the orange wire. I also had to add a cap so cancel out the pulsing effect since the fog relay doesn't like that.
Old 06-14-2016, 09:46 AM   #6
IllusionX
Yeah, I went with 100w H4 bulbs in the end on my echo, until I sold it.
Low beams & High beams on together? Deathegg DIY / Maintenance / Service 26 12-22-2018 10:19 PM
Low Beams not working Karri'es Yaris DIY / Maintenance / Service 7 02-10-2012 08:34 PM
Problem with low beams and High Beams thebarbrr DIY / Maintenance / Service 7 09-22-2010 08:43 AM
Fog lamps as back up low beams. ellenbetty General Yaris / Vitz Discussion 114 10-22-2009 03:40 PM
